location of the ignition control module
1986 DODGE RAMCHARGER
SMITH RYAN
location of ignition control module in a 1986 dodge ramcharger with a 318
Apr 11, 2012 at 8:22 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
on the passenger side of the engine compartment, look at the post and image below.
Best, Joe
Apr 11, 2012 at 8:40 PM
  • 54,350 POSTS
Hey SMITH,
I looks like it is on the passenger side of the engine compartment or down low on the firewall on the drivers side , here are diagrams for you to help get the problem fixed.
Cheers, Ken
Feb 28, 2017 at 3:49 PM
M MORTON
where is the ignition module located on a 87 dodge ramcharger
Feb 28, 2017 at 3:50 PM (Merged)
TRACY CROCKETT
I cannot find the ignition control module anywhere along the fire wall. Where is it exactly located?
HMAC300
  • 48,601 POSTS
see picture. it may be on the fender-well between washer fluid tank and firewall. also, check ballast resistor as that used to a big problem especially if when you crank it fires then quits when you let off.
