1990 Lincoln Town Car Repair Question
Topics covered: Engine, Suspension, Noise.
Asked on July 3, 2008
1990 Lincoln Town Car check engine and air suspension light
Today, after being on the road for about fifteen minutes, my 1990 Lincoln Towncar's CHECK ENGINE light came on. I thought I heard a noise (like a high pitched noise) when I noticed the light on. After about three minutes, the CHECK AIR SUSPENSION light came on. When I got home I killed the engine and then restarted it. The lights did not come back on and the car was idling normally. Any suggestions?
Answer
Replied on July 3, 2008
You can test for codes, here's how:
Replied on July 30, 2008
YOUR CHECK E LIGHT HAS NOTHING 2 DO WITH UR AIR SUSP LIGHT, IS THE CAR SITTING LOW AFTER SITTING, DOES AIRLIGHT COME ON WHILE DRIVING? AIR PUMP ONLY SHOULD COME ON WHEN STARTING,NEW PASSENGER,OR MORE WEIGHT ADDED 2 CAR. IF IT(PUMP) COMES ON SPERATICLY, U HAVE A LEAK IN THE SYSTEM, USUALLY THE AIR SPRINGS, IF NOT REPLCED, PUMP WILL BURN OUT. ARNOTT INC . IS THE PLACE 2 CALL, 4 NEW PUMP,AND 2 NEW AIR SPRINGS.EZ 2 INSTALL. 365.00 FOR THE KIT. COIL SPRINGS R AN OPTION.60.00 AT PEPBOYS OR AUTOZONE STOPS THE HEADACHE, TAKES AWAY FROM THE RIDE THOUGH
You are answering 30 day old questions, and the first line of this question stated that the "check engine light" was on...then the air suspension light.
