Mechanics
REPLACING THE THERMOSTAT
2004 Lincoln LS
Engine Cooling problem
2004 Lincoln LS V8 Two Wheel Drive Automatic 80,000 miles
Can you let me know the location and how to replace the thermostat on my 2004 Lincoln LS V8?
Thank you,
David
Fonner
June 28, 2010.
Remove the air cleaner outlet tube.
Drain the cooling system.
Disconnect and position the lower radiator hose out of the way.
Remove the bolts and the thermostat housing.
Remove the thermostat and the O-ring.
To install: NOTE
Clean all the sealing surfaces and inspect the O-ring seals thoroughly.
Replace the thermostat and the O-ring.
Install the bolts and the thermostat housing.
Connect the lower radiator hose.
Bluelightnin6
Jun 28, 2010.
AD
