2001 Lincoln LS misfiring in the engine!
2001 LINCOLN LS
81,000 MILES • V8 • 2WD • AUTOMATIC
BUBBA5252
i had a misfire show up when i got my car checked changed the spark plugs...and then it showed a ignition coil malfunction on coil h so i changed that coil and alll the spark plugs car ran fine for a bit then a misfire came back up first it was misfiring on cylinder 8 now its 4 so i dunno wat the problem could be?
May 11, 2009 at 8:57 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
You are going to replace one coil at a time between 80K and 100k miles and when its in for a tune up we recommend it that coils be changed too good luck.
May 11, 2009 at 9:03 PM
BUBBA5252
so are u saying that i need to change all the coils then?
May 12, 2009 at 8:33 AM
BMRFIXIT
  • 19,053 POSTS
I believe and ive seen it they are going to fade out one after the other
you can replace them as they fail or all at once
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 12, 2009 at 4:41 PM
