Park Assist Sensor replacement
BJHELF4
  • 2005 LEXUS LS 430
  • V8
  • MANUAL
  • 110,000 MILES
I need to replace the park assist sensor in the front bumper cover on a 05 lexus 430 LS
Do you
have the same problem?
Thursday, December 23rd, 2010 AT 2:46 AM
KHLOW2008
  • 41,815 POSTS
Attached are diagrams and instructions for removing the front bumper on which the sensors are located. Skip steps that are unnecessary. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, December 23rd, 2010 AT 2:08 PM
HENRY1
  • 2005 LEXUS LS 430
  • V8
  • 61,848 MILES
Park assist beeper doesn't sound and screen display doesn't indicate when approaching an object near bumper sensors.
Thursday, December 10th, 2020 AT 9:04 AM (Merged)
DAVE H
  • 13,383 POSTS
Have the vehicle plugged into a diagnostic computer both system have their own ECU (computer) and should supply fault codes for the where the fault in the system is located?
MICUE
  • 2005 LEXUS LS 430
Electrical problem
2005 Lexus LS 430 V8 Two Wheel Drive Automatic 34.000 miles
Hello Sirs,
How difficult is it to replace the last front bumper sensor on passenger side of of automobile? Can you give some insight?
Thanks
JCHAGE10
I don't know if you still need help or not, but I just replaced my sensor this weekend. It was the passenger side, #2 from the edge. The sensor cost me about $200 but don't forget to get the clip for it if yours is broken. I had to unscrew the plastic panels from underneath the car. The whole panels are a major pain to remove so I loosened up the front screw sets only of the panel on the side, then the front and middle row of the center panel. That allowed me to pull it down enough to get my hand in and reach the sensor. From that point on, I had to do the whole thing blindly. THe clip slide from the side to the center of the car, then you push the sensor out, then unplug it (it had a little plastic thing you have to push down to unpulg it. Then put the new sensor in (insert if from the outside), plug the wire in, then "clip it" (slide it center to outside). The sensor ir parallel to the ground and the wire is from the outside.
Very complicated, I know. It took me about 2 hours.
Then screw the panels back in and you're in business.
The only issue left to figure out for me, is on the screen, top left, the lines showing up on that tiny car thing, on the side I replaced afre now yellow. But all works well.
I'm gonna google it and see how to "fix" that.
Hope this helps.
