2001 Lexus IS 300 Repair Question
Asked on July 10, 2009
Lexus IS 300 Coil pack Problem
Engine Performance problem
2001 Lexus IS 300 6 cyl Two Wheel Drive Automatic 127000 miles
having cylinder 2 missfire codes pop up and CEL (P0302) i have allready replaced the coil packs for cylinder 1,2 and 5,6 , new iridium plugs, and still having the code pop up and can feel the car shake when idling and missfires while driving. Please help me. my dealership said to change out the coil pack which i did and it still hasnt fixed the problem
Answer
Replied on July 17, 2009
did you replace the coil with a new or used? Did you check to see if you are getting an injector control to the injector?
