head bolt torque
1998 LEXUS GS 300
200,000 MILES
ANONYMOUS
head bolt torque specifications and sequence
Apr 9, 2013 at 3:59 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Here is a video on how to use a torque wrench and the diagrams below to show you the specs.
https://youtu.be/juOClONIWeY
Apr 16, 2013 at 11:15 AM
2BTTML
i understand that the correct torque is 25 foot pounds and 90 degrees and 90 degrees but i would like a diagram of the torque sequence. if possible.
Oct 7, 2018 at 8:25 PM (Merged)
CARADIODOC
  • 34,309 POSTS
Try this on for size. This is from ProDemand.
CARADIODOC
  • 34,309 POSTS
That worked so well, I want to do it again!
RDPHAM07
I have a repair manual both the book and CD. In the book it tells me that the bolts should be tightened to 25 foot pounds of torque plus an additional 90 degrees, but on the CD it tells me to tighten the bolts to 25 foot pounds of torque plus an additional 180 degrees. I was wondering which one is the proper way to tighten the bolts?
  • 31,937 POSTS
Hi there,
Step 1. 25Tf/ib
Step 2. 90 Deg
Step 3. 90 Deg.
Do not tighten 180 Deg in one go, this must be done in 3 steps and new head bolts must be used with all torque to yeald bolts.
Mark (mhpautos)
