1996 Lexus ES 300 fuelpump
1996 LEXUS ES 300
103,159 MILES • 6 CYL • FWD • AUTOMATIC
FARZOUT
front end accident. pulled out damage. is there a reset switch? is there a gas cut off switch,or a shut off valve,when you get in an accident? fuel pump does not kick on, however it does kick on when you use a jumper box for a power source, to go direct to top of fuel pump wiring!does the crank position sensor switch have anything to do with any of this?
Mar 29, 2010 at 1:41 AM
