security system
2000 KIA SPORTAGE
LORIBETH70
how do you reset the security system on a kia sportage
Dec 11, 2010 at 11:54 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
Hey Loribeth
Here is a guide to help you reset your alarm system on your car. I would try disconnect the battery negative cable and then hold it to the positive terminal of the battery which will discharge the capacitors and hard reboot the system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Please let us know what you find so it will help others.
Best, Ken
Dec 4, 2016 at 2:06 PM
CBARKLEY
4 cyl Four Wheel Drive Automatic 70,000 miles
i took out the old battery and attempeted to install a new one but every time i do the alarm sounds off and want stop buzzing , i have tried to search if there may be a fuse where i can just unplug the alarm. i tried inserting my key in the door to reset the alarm but no luck , with the alarm going off i am not able to crank the car please tell me how to either disarm the alarm or rest it please and thanks inadvance
Apr 10, 2018 at 3:24 PM (Merged)
  • 110,190 POSTS
Disconnect the battery then turn the ignition key on and reconnect the battery worked for my car.
Here is a guide that will help as well.
You could also try unlocking the rear door/gate to disarm the alarm. Sometimes they have that lock disarm
Cheers
