2003 Kia Sorento Repair Question
Topics covered: Axle, Differential, Driveshaft.
Asked on April 6, 2009
2003 Kia Sorento rear drive shaft
Drive Train Axles Bearings problem
2003 Kia Sorento Two Wheel Drive Automatic 75,000 miles
The bearing in the rear drive shaft of my sorento has gone bad. I have found a rear drive shaft for a 4X4 2003 kia sorento. Will this work in my 2WD sorento?
Answer
Replied on October 13, 2009
The driveshaft doesn't have a bearing. The differential does as well as the transmission. Which are you refering to? Also, I strongly recommend staying with direct fit parts. No matter what, there always seems to be problems when you interchange parts like this. Most likely it will be different. You could call a parts store and see if the part number is the same between the two different vehicles. If they are the same, it should work.
Let me know what part we are talking about.
