timing marks has jumped?
2005 KIA SEDONA
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERTPARK
how do I reset the timing on a 2005 Kia sedona 3.5 DOHC once the timing has jumped so that the valves do not slam into one another, Is there a way to know if you have the cams in the correct position when timing marks are in line
Aug 12, 2010 at 11:30 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2570.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_644.jpg
Heres another diagram that shows all of the timing marks
Aug 12, 2010 at 11:44 PM
SRBSTN2256
  • 62 POSTS
Six cylinder two wheel drive automatic.
Need timing belt diagram.
May 26, 2019 at 9:09 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_524.jpg
KGJULIE
  • 6 POSTS
Engine Mechanical problem
2002 Kia Sedona 6 cyl Automatic 110000 miles
I had the timing belt in my 02 sedona replaced at 110k miles. After 2 days in the shop, I picked it up and the whole car vibrates, whether driving or idled. I took it back to the shop and they set the idle lower. It doesn't vibrate as bad, but when stopped feels like the car is going to die. Also pickup/acceleration from a stop is now very sluggish, car vibrates until about 20 mph, then smooths out. After idle set lower, now check engine light is on, took it back to shop, they said it is a misfire on cylinder 6. They replaced spark plug, wires, fuel injector, some kind of coil, check eng light still on and car still idles and drives very rough. My Q is: is the second problem of the idling and the cylinder misfire related to the timing belt repair (i.e., could it have been a poor/botched repair job)? Know nothing about cars, but 5 days in shop seems excessive. They have no idea what the problem could be.
DOCFIXIT
  • 18,828 POSTS
Hi
Did belt break or maintenence? The belt is not on properly they have cams out of time with crank. When they lowered idle that set light off. As for the miss that's there because belts not on properly.
Have you used this shop before?
Let me know
THanks for donate
KGJULIE
  • 6 POSTS
My service manual called for it at 60k miles, so it was just maintenance, not an actual repair for a broken part.
I have never used the shop before, I'm just wondering if it's time to ask for a refund. That's why I wanted to know if the problems I'm having now are related to the timing belt replacement. At the shop this morning, the tech made it sound as if they are NOT related, and my car has developed new problems.
The car was in the shop for the repair for 2 days, and now 3 more days trying to fix the additional problems (rough idle, check engine light, slow/shaky acceleration).
Thank you very much for your insight!
KGJULIE
  • 6 POSTS
Hi -- the mechanic said this morning (4th additional day of car in shop) that there is no problem with the timing belt -- he has "opened it up" and checked it 3 times since replacing the belt.
STILL having all the same problems, very rough idle/drive, CEL on, poor acceleration from stop. He said he checked all the cylinders and they are all showing compression of 150-155 (within 20% of each other). He cannot figure out what the problem is (he reiterated that he already changed spark plugs, wires, fuel injector on that cylinder and some kind of coil on that cylinder).
My question is: is there any way to tell if these problems were caused by the original work (i.e., the timing belt replacement)? The original work was $1400+, I have no clue if this shop is being honest with me or not.
Thanks.
DOCFIXIT
  • 18,828 POSTS
Will you get code from shop in P0xxx format? Also have they checked cam and crankshaft sensors?
KGJULIE
  • 6 POSTS
Mechanic called. The hydraulic tensioner timing adjustor is broken. He's not sure if it was broken or starting to fail prior to the belt replacement, or if it got broken during the replacement process. He's willing to fix it for free if I just pay the $195 for the part. Does that seem reasonable?
Also, he says there is a bad engine valve which is responsible for the cylinder misfire. Does this sound right? Fixing this is a $1000 problem btw.
Thanks for any additional help.
DOCFIXIT
  • 18,828 POSTS
I think they damaged auto adjuster causing timing to be out and possibly damage to valve. Ask them what was the measurement of rod protruding from tenisioner during adjustment. If they can respond measurement is 3.8 to 4.5mm ie. milimeter.
And what are all 6 cylinder compression test readings.
Let me know
KGJULIE
  • 6 POSTS
Hi -- he said the tensioner rod was about 1/8 inch (didn't know what it was in millimeters) but it wasn't holding pressure and would just "collapse all the way back in." Also the cylinder readings are:
1-5 dry = 150
1-5 wet = 170
#6 dry = 75
#6 wet = 100
I hope this helps. Thanks a million for your input.
KGJULIE
  • 6 POSTS
that when I picked the car up after the timing belt replacement and the first two subsequent days in the shop trying to fix the vibrating idle, CEL light problems, the mechanics told me they were sure there was nothing serious wrong and the van was OK to take on a planned road trip. So last weekend I drove about 1200 miles, then I brought it back in on Tuesday and it's been in the shop again all week. I'm pretty sure now that driving the 1200 miles on it was not so good and may have caused some of the damage...
DOCFIXIT
  • 18,828 POSTS
O.K.
That is correct measurement it should hold that measurement so if it is not then tensioner is faulty. As for compression readings #6 is in trouble but it is not the valves because pressure came up when wet test done. That indicates a ring problem.
HLACEFIELD
The answer is wrong. Oil will also increase bent valve compression. Mechanic bend valve(s) when doing timing belt replacement. There is a bent valve(s) on #6, not piston rings. Make mechanics fix it.
Mar 27, 2025 at 12:35 PM
  • 54,354 POSTS
Can I ask how you think oil will help a bent valve seal?
Mar 28, 2025 at 10:00 AM
