Water pump replacement
BRIAN DUNKEL
  • 2005 KIA RIO
  • 3.6L
  • 4 CYL
  • 200,099 MILES
How to change the water pump?
Thursday, December 28th, 2017 AT 7:37 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
This is a 1.6l, not a 3.6l and here are the instructions as well as a diagram.
Caution: Do not disassemble water pump assembly. If a problem is found, replace assembly as a unit.
1. Disconnect negative battery cable.
2. Remove drive belt.
3. Remove timing belt.
4. Remove power steering pump in order to remove water inlet pipe.
5. Remove components in the order shown in illustration. See Figure.
6. Installation procedure is reverse of removal.
Friday, December 29th, 2017 AT 6:08 AM
ERKIRE
  • 2003 KIA RIO
  • 4 CYL
  • 10,200 MILES
Replacing timing belt and also water pump. I need the torque specs for the pump it self.
Thursday, July 16th, 2020 AT 6:21 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Water pump bolts torque to 14 - 19 Ft. Lbs. (19 - 26Nm)
Water pump pulley bolts torque to 9 - 13 Ft. Lbs. (12 - 17Nm)
THEODORE1953
  • 2003 KIA RIO
Engine Cooling problem
2003 Kia Rio Automatic
while changing the thermostat on a 2003 kia rio I accidentally pulled the water pipe out of the end of the water pump-it looks like it just pushes in there and has an o ring on it.I didnt see that coming -the water pipe has a welded on strap that is is hooked over the stud that holds the thermostat housing on-one side has a bolt-the other has a stud with a nut on it.I didnt realise I couldnt pull the pipe back enough to get the housing off. But anyway. Here I am.I need to know if I can get the water pipe back in so it doesnt leak or if I need to do something more drastic. Thanks. Ted
BLACKOP555
  • 10,371 POSTS
Get a new o ring and try to push it back in then give it a thin layer of rubber safe lubricant and push it in there. Should go right back in. No big worry!
MESHELLE MAXWELL
  • 2002 KIA RIO
  • 1.5L
  • 4 CYL
  • 95,000 MILES
How can I remove a broken water pump bolt in the block? There is not enough room to use a drill.
Thursday, July 16th, 2020 AT 6:22 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi Meshelle,
For such situations, the only way to go about is to make sufficient room for the drill and it might mean raising or lowering the engine, ie, with engine mounts removed. Worse case is either to lift engine either partially or fully out of vehicle.
If there is still a short piece of stud sticking out and hopefully the broken stud is not fused due to rust. You might still be able to remove it with a pointed punch and hammer.
Tap the stud to try to make it turn anticlockwise and if it can move, then continue until you get sufficient grip with a grip pliers to remove. When tapping, do not hit hard, just gentle taps to vibrate the stud to move.
Good luck.
MESHELLE MAXWELL
Thank you but he tried ez out and it busted in block also now he now made it smooth on top to the block now should he do what u suggested
KHLOW2008
  • 41,814 POSTS
If the broken cannot be removed then it has to be drilled out and rethreaded to enable proper installation of the water pump. All bolts must be installed failing which it would result in coolant leakage.
He has to find a way of getting the broken piece out.
CARADIODOC
  • 33,760 POSTS
If nothing else works, I have a possible solution, but it requires an acetylene torch, a wire-feed welder, and room to get in there with them. A propane torch will not work as it does not get hot enough. I will check back tomorrow to see if you made progress.
RENEE L
  • ADMIN
  • 1,257 POSTS
I merged both questions together so that everyone is on the same page. Thank you HEYMAN1104.
Renee
AMBERST.CLAIR85
  • 2002 KIA RIO
2002 Kia Rio 4 cyl
My father is going to change the water pump on my Kia and we need to make sure he has all the information we need.
Removal
Caution Do not disassemble water pump assembly. If a problem is found, replaced assembly as a unit.
1.Disconnect negative battery cable.
2.Remove drive belt.
3.Remove timing belt.
4.Remove power steering pump in order to remove water inlet pipe.
https://www.2carpros.com/forum/automotive_pictures/12900_w_2.jpg
5.Remove components in the order shown.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
2CP-ARCHIVES
  • 4,540 POSTS
  • 2001 KIA RIO
  • 270,000 MILES
Im trying to replace water pump, whats the easiest way to go about it?
Thursday, July 16th, 2020 AT 6:23 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Ony standard procedures that requires timing belt removal.
WATER PUMP
Removal
Disconnect negative battery cable. Drain coolant. Remove accessory drive belt. Remove timing belt. Remove power steering pump. See
Fig. 17. Remove water inlet pipe and gasket. Disconnect water bypass pipe and "O" ring. Remove water pump drive pulley. Remove water pump bolts, and remove water pump. Remove gasket and clean gasket mating surface of engine block.
Installation
Ensure all gasket mating surfaces are clean. Install water pump gasket on water pump. Install water pump. Tighten bolts to specification. To complete installation reverse removal procedure.
DAVE79AU
  • 2000 KIA RIO
  • 1.5L
  • 4 CYL
  • FWD
  • MANUAL
I had to replace the water pump the old one was leaking water very quickly so I got a new one and fitted it and put everything back together and then started the car it didn't leak until it warmed up a bit then it started to leak again so I took it apart to see if I missed a bolt or if they needed tightening up again anyway after all that I put most of it back together again to find it is still leaking now I've worked on heaps of car over the last 25 years and never had this problem any help will be grateful.
DAVE79AU
Ok all good worked it out all fixed now and no leaking
TY ANDERSON
  • 684 POSTS
Just curious, what was leaking and how did you find it?
DAVE79AU
Because of how small a space you have to work with u can't see very well and not a lot of light gets in to but what I found was when I changed the pump over I didn't see that I left a bit of the old gasket there so it pays to have a torch handy so you can get more light in and really look properly
Thursday, July 16th, 2020 AT 6:24 PM (Merged)
TY ANDERSON
  • 684 POSTS
Good to hear.
Sometimes the littlest of details makes the difference. Thanks for sharing.
