2001 Kia Rio misfiring
2001 KIA RIO
90,000 MILES • 4 CYL • FWD • MANUAL
SCREWDRIVER
replaced head gasket was loosing compression in cooling system ,corrected,now will not idle, surges seems to be missing checked timing belt alignment,good pumped air into cylnders with valves closed checked good,upstream o2 sensor wiring found pulled apart will sensor cause problem?
Apr 23, 2009 at 5:01 PM
