Passenger door wont open
HSETT
  • 2005 KIA OPTIMA
  • 4 CYL
  • FWD
  • 147,000 MILES
The passenger side door wont open. I know this is common in this year, but how can I fix this? Can I take the door lock fuse out?
Tuesday, October 18th, 2016 AT 5:36 PM
HMAC300
  • 48,601 POSTS
Pull door panel off if you can get the screws out, then check where rods connect for a broken clip or rod off. Sometimes you have to remove the seat to get access to get the door panel off. I think clips are available at auto parts. See pictures.
Wednesday, October 19th, 2016 AT 6:56 AM
ISLANDSUN187
  • 2004 KIA OPTIMA
  • 4 CYL
  • 82,000 MILES
I have a 2004 Kia Optima and the driver door won't open anymore from the inside or outside. First of all, what would be the cause of this and second what is the best method to go about solving the problem. Or at least getting the door open?
Sunday, March 10th, 2019 AT 11:54 AM (Merged)
  • 108,289 POSTS
It sounds like the linkage has either broken or fallen apart. To access it and determine the problem, you will need to remove the inner door panel. It's the only way to get to it.
SPARKYTJ1
  • 12 POSTS
  • 2007 KIA OPTIMA
My question concerns an Optima Kia 4 door. My front passenger side door will not open from either the inside or outside. All other doors work fine. What could have happened to cause this door to stop opening?
HMAC300
  • 48,601 POSTS
You will have to get teh door panel off and see if a rod has fallen off or a clip broken that holds the rod to activate teh door. Make sure you don' thave the poser door lock engaged.
GARYGREENE
  • 2003 KIA OPTIMA
  • 4 CYL
  • 85,000 MILES
The driver side door won/t open. I have taken the passenger door inner panel off for a reference. The problem appears to be the linkage does not work between the door handles and the release mechanism. How can I get the driver side door off if I can't open it?
1992_F-150_GUY
I have the exact same problem, can't get the door open. Any ideas?
LADYCOOP73
  • 2004 KIA OPTIMA
  • 4 CYL
  • FWD
  • 87,000 MILES
I can unlock the doors but the drivers side door will not open. It doesnt appear to be fully unlocked and the door will not physically open from the inside or out.
KHLOW2008
  • 41,815 POSTS
Hi ladycoop73,
Did you try manually operating the locking knob before opening?
If it don't work, then most probably the loak is faulty.
If after manualy operating the knob you can open the door, then the actuator motor is weak, you need to replace it.
DONNAKIA
  • 2004 KIA OPTIMA
Electrical problem
2004 Kia Optima 4 cyl Automatic 62000 miles
Lock opens, but door will not from inside or out.
Has anyone found a solution.
Is it electrical?
KHLOW2008
  • 41,815 POSTS
Hi donnakia,
Should be mechanical, you have a faulty door lock.
DONNAKIA
You are absolutely right. I went to the mechanic today and thats what he said.
Thanks
