1999 Jeep Wrangler Brake Lights
1999 JEEP WRANGLER
84,000 MILES • 6 CYL • 4WD • AUTOMATIC
ESTRELLALL
Side brake lights do not work; only middle brake light works. If headlight switch is turned on, the rear brake lights do light up, but do not get any brighter when the brakes are applied. Also, the hazard lights do not work at all when turned on. The right directional blinks quickly when engaged; the left seems ok as long as the lever is set at an exact spot. Tried the obvious first - switched out the bulbs. Still no side brake lights. Thanks for any insight.
Apr 21, 2010 at 1:03 PM
