I have a 98 Jeep Wrangler and the battery was drained all the way down. I put a charger on it and now do not have any spark or any fuel in the rail, or in the cylinders. When the key is turned to the "On" position, gauges do not move and the check engine light does not appear. I replaced a crank position sensor, as that is a common problem on these 4.0L Jeeps. Tested all fuses and they are good, as well as the underhood relays.
Feb 23, 2008 at 6:20 PM
