Reset alarm
2003 JEEP LIBERTY
162,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
TC77
My daughter push the alarm button, could not turn it off, started the vehicle, did not help. Had to disconnect the battery. Is there a way to reset the alarm?
Jun 16, 2014 at 6:58 PM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
I would try a hard reboot which means to hold the negative battery cable to the positive terminal for one minute this will discharge the capacitors in the system and let it reboot. Here is a guide to help you:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Cheers
Jun 16, 2014 at 9:45 PM
JNOVACK
  • 723 POSTS
Is it factory installed or is it after market?
Jul 16, 2018 at 6:43 PM (Merged)
JANA_LEIGH14
I just got the vehicle, but it was a lease back, so I am sure that it would be factory installed.
JNOVACK
  • 723 POSTS
Check with dealer to make sure they did come from dealer with alarm if they say it is not factory then under dash driver side there should be a black box hidden under therewith a bunch of wires coming out of it going to the ignition module. Unscrew the one bolt remove the adapter and put back together now the alarm is no longer. But if they say it is factory they will have to disable it you cannot not with out shutting down whole electrical system.
JANA_LEIGH14
Thanks for your help!
KYLEWORM1953
If any water gets near fuses or body module on drivers side inside will cause this problem. Did to mine after a hard rain and after a few warm no rain days hooked battery back up and my Cecile would work okay again. Mine has a cracked windshield and water is getting in near this area so try blowing this area out with air hose to remove the water if you have any could be your problem. Time for a new windshield for me. After new windshield mine working the way it should. As for disable alarm dealership said with factory alarm they cannot turn off. It is located in body module at $1,000.00 plus labor. Glad mine was only a bit of water. Hope this helps someone.
