oil pressure sensor location?
2004 JEEP LIBERTY
46,000 MILES • 6 CYL • 4WD • AUTOMATIC
PONDER692002
the oil light comes on intermittently and not sure why.it is full of oil and i always use synthetic oil.do you think it's a sensor?
Jan 9, 2010 at 5:58 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
the oil pressure sensor is down by the oil filter. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Dec 15, 2020 at 8:47 AM
OINKLEY
Where is the oil pressure sensor located on a 2002 Jeep Liberty 3.7L? What is involved with replacing it?
Thankyou
Dec 15, 2020 at 8:47 AM (Merged)
Its on lower left front of engine above oil filter-unplug it then remove the sensor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
DENNISL1
the oil lihgt comes on while driven and at a stop. but then again the light will not come on at all.could it be the senser.if so where it would be located.
BLUELIGHTNIN6
  • 16,542 POSTS
the engine oil pressure sensor is located on the lower left front of engine,above the oil filter. you may want to check the oil pressure with a mechanical oil pressure gauge, if it really is low then could be a failing oil pump.
OINKLEY
Electrical problem
2002 Jeep Liberty 6 cyl Four Wheel Drive Automatic
The oil light came on at idle when engine was warm. I replaced the oil pressure sensor and the connector pigtail. Now the oil light comes on at 2000 rpm. I checked the oil pressure with mechanical tester. Oil pressure was 28 psi @ idle, and 65 psi @3000 rpm. This seemed within specs. What should I look at next?
Thankyou
  • 110,190 POSTS
Try a different sending unit. It sounds like the new one is bad.
Let me know if this helps.
