1993 Jeep Laredo why does my grand cherolee stalls when on
1993 JEEP GRAND CHEROKEE LAREDO
158,000 MILES • 4 CYL • 4WD • AUTOMATIC
JEEPGC93
OK more than a year ago my car started stalling sporadically. The first time it happened was on summer time, it stalled almost every time when i came to a stop or at a light, as the weather got cooler the problem went away with no issues at all during winter time,it was until this summer when it all came back. before it used to stall every now and then or when it was very hot around 90s, now i cant even drive it a few yards because it stalls every time, then i wait a few seconds and i start it back up with no problem, I already replaced the TPS, i tested the IAC, Sranckshaft SENSOR, replaced the FUEL FILTER(BY THE WAY THIS ONE WAS A LITTLE CLOGGED AND WITH SOME DIRT INSIDE OF IT)(HAVENT CHECKED THE HOSES YET), checked The RELAYS and Fuses, the RESISTANCE of the injectors, and they all checked ok. I dont know if may have something to do the fact that before the stalling problem i overheated the car when i drove it with a broken hose (coolant) until the motor shut off (i know this sounds stupid but i was close from home and i didnt want to pay for towing i tought i was gonna make it.)after that i fix the hose, gave it a tune up and seeme to be ok. Do you guys think that maybe one sensor could have damaged because of that?. Thanks for taking the time for reding my post and hopefully you know of any solution or suggestions to my problem. Thanks again
Oct 12, 2008 at 5:35 PM
