1998 Jeep Cherokee Will not start....sometimes
1998 JEEP CHEROKEE
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
TEJOTA69
When I turn the key to start, it will not crank, click or anything. If I play with the key a while, turning off, then on, then off and back on, eventually it cranks and tuns on like nothing was wrong in the first place. I've replaced the starter/solenoid and still have the problem. What do you think might be the problem?
Thanks,
Tom
Miami, Fl
Jan 23, 2008 at 2:05 PM
  • CAR REPAIR CONTRIBUTOR
Check the battery/connections-that's okay. Get a repair manual see below your post and troubleshoot the ignition switch/transmission range switch/starter relay
Jan 23, 2008 at 2:18 PM
