1993 Jeep Cherokee leaking in the back passager floor board
1993 JEEP CHEROKEE
158,000 MILES • V8 • 4WD • AUTOMATIC
LITTLEWOLFPLAYING
my back passenger floor board is full of water and i have had no rain it weeks so i have to be-leave it is from the a/c but the front floor board is dry as a bone. so i guess my question is. is there a a/c drain tube that runs under the back passenger floor ? or how do i fix the stoped up drain line?
Aug 8, 2010 at 12:57 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
The floor pan is designed to channel water to the rear, the drain requires you to get under the jeep, at the firewall on the passenger side, where the A/C evaporator case meets the firewall, you will find the drain. Clear it with compressed air, or carefully with a piece of wire., Peel the rug back and remove the rubber drain plug to help get rid of the water back there.
Aug 9, 2010 at 1:19 PM
