2CarPros - Car Questions & Answers
2000 Jaguar XJ8 Repair Question
Topics covered: Transmission, Jack, Limp mode.
Asked on June 9, 2010
2000 Jaguar XJ8
Transmission problem
2000 Jaguar XJ8 V8 Two Wheel Drive Automatic 104000 miles
i have a 2000 jaguar xj8 that seems to be stuck in 4th gear. it goes in reverse fine but when you put it in drive it revs up to about 2000 rpm and then jerks reak hard and drives off very slow. it also says gearbox fault when the car jerks. i scaned it and got the following codes 1646,1647,0706,1722,1000. is this something inside the transmission or something with a computer?
Avatar Asked by 1bimmer3
Answer
Replied on June 25, 2010
HI
The first thing to check is the gear selector cable for correct adjustment.
The car has gone into limp mode and stays in forth gear.
Also check condition of electrical conectors for the selectror and selectror moves through it positions freely with nothing loose or damaged.
Regards
stypejack
Tiny Answered by stypejack
3 questions asked
