1995 Jaguar XJ6
Ive had this Jaguar for a year now and on a couple occasions when you go to start it you turn the key and all that will happen is a click. Put it in neutral and again just a click. The click sounds like its coming from , what I would think, is the selenoid on the starter. In the past I have tapped the starter and within a couple minutes of it not starting it will.
Last Friday I came out of a store and it would only click. I could not do anything so I got a ride and came back the next morning only to have the car start fine. I then drove it (on and off) to a few places until monday afternoon when the same problem happened again. It is now Thursday and the car still only clicks.
Upon asking others I have done and checked a few things.
Battery is fully charged and getting good contact. Plus the car has been a AZ car its whole like so no rust issues.
I was told if the brake light switch is bad it will do this, check that and its fine.
I also have been told it could be the neutral safety switch but where is it located and what kinda part number does it have.
Here is the other thing. I have an identical, front end hit, 95 Jaguar parts car so I can grab whatever is needed off that but kinda need to know what direction to go in.
Thanks in advance. Donation could be forthcoming
Jan 14, 2010 at 11:36 AM
