ABS light, brake light and battery light on
1999 ISUZU RODEO
200 MILES • 6 CYL • AUTOMATIC
DAWN LAYMAN
Cold start. Car was driven for about four minutes with the AC on high this morning. Heard weird noise coming from engine and turned off radio and AC. Noise stopped when AC turned off. ABS light came on so I started tapping my brakes to make sure I was not going to shut off. About that time, the brake light and battery light started flickering, coming on and off. Ticking noise when lights were coming on and off. Stopped at a red light and car started idling high 2000 and when went to accelerate, the car was barely moving. Finally got it going to an acceptable rate. Turned car off and let it sit for four hours until help arrived and everything seemed fine when they restarted it. No lights, nothing. Drove it one hundred feet and had a little jerk in the movement of the vehicle and lost acceleration again with all lights back on. Any suggestions?
Jul 26, 2017 at 2:36 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
It sounds like it could be the AC compressor but lets start by checking the alternator which can cause the problem you have described.
If it fails this guide will help walk you through replacement. Please run this test and get back to us we are interested to see what it is.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Jul 28, 2017 at 11:28 AM
TSGTGENE
Thanks for this post I had this problem and had to replace the alternator cost me 143.00 all fixed!
Apr 29, 2019 at 6:20 PM
JMANG525
Engine is racing most the time. Must hold the brake down on drive instead of stopping in N at lights because its racing too much. Alternator lights shows HOT engine heats up and cuts off. Radiator full not over heated but engine is.
Apr 29, 2019 at 6:21 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi jmang525,
If the radiator is not overheating, then it could be a faulty thermostat.
The engine racing at idling indicates a fault with the idling system and it could be vacumn laekages or a faulty Idle Air Control valve.
DAVIDWSEMIEN
1997 Isuzu Rodeo Question Manual
Recently my rodeo brake and battery light came on so I got my alternator tested and it ended up being bad. I replaced my alternator and purchased a new battery. After installing everything my car starts up with no problem now but the brake and battery light is still on. I am really at a lost and do not know what steps I need to take next in order to solve this problem. Thanks
2CARPRO JACK
  • 11,533 POSTS
To begin there are a few fuses to check.Underhood- main fuse #16. Under dash fuses,#3 and #7.If all fuses are ok, you may have a problem with the engine control module which is located under thecenter of the dash and is what controls the alternator output. Here is the wiring diagram for your vehicles charging system
https://images.2carpros.com/forum/automotive_pictures/1639_isuzu_2.jpg
