1995 Isuzu Rodeo Question WOn't start
1995 ISUZU RODEO
156,000 MILES • 6 CYL • 4WD • AUTOMATIC
PURPLEHAZE1965
My Rodeo had a sensor over heat and shut the truck down a whilke back . When the engine cooled off it started and has not done it again since the weater cooled off. Now the truck won't start. It is trying and right on the edge of running but won't quite take off. What would be the most common sensor to cause this problem? I guess I cleared the comp codes a couple weeks ago when I changed the battery so I don't know where the system failure was.
Jan 12, 2008 at 2:08 PM
PURPLEHAZE1965
[quote:7f750abd1e="PurpleHaze1965"]Other Category problem
1995 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 156000 miles
My Rodeo had a sensor over heat and shut the truck down a whilke back . When the engine cooled off it started and has not done it again since the weater cooled off. Now the truck won't start. It is trying and right on the edge of running but won't quite take off. What would be the most common sensor to cause this problem? I guess I cleared the comp codes a couple weeks ago when I changed the battery so I don't know where the system failure was.[/quote:7f750abd1e]
Jan 12, 2008 at 2:13 PM
