1995 Isuzu Rodeo Repair Question
Topics covered: Engine, Piston, Compression.
Asked on July 27, 2008
1995 Isuzu Rodeo Question Help with Timing belt
My Timing belt blew while driving. We followed the Haynes book and replaced it. I lined up the Came shaft marks to the cover. The Crank Sprocket to it's marks. After putting it all back together. It won't start. It turns over but now the intake butterfly valve pushed air out instead of sucking it into the engine. Is the timing off? I ensured the # 2 Piston was TDC. Could something else be wrong Or was it operator Error (ME). Any help would be gladly appreciated.
Thanks.
Answer
Replied on July 27, 2008
Put the engine no.1 piston on its compression stroke/TDC then line all the timing markings
What is it a SOHC or DOHC 3.2L
Thanks,
DOHC, The book says No 2 Pistion. Should I do it on No 1. Willthat damage the engine?
Replied on July 28, 2008
J
