2CarPros - Car Questions & Answers
1994 Isuzu Rodeo Repair Question
Topics covered: Timing belt, Ignition timing, Engine.
Asked on September 13, 2010
Question timing belt
Engine Mechanical problem
1994 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 174134 miles
How do u check and adjust the timing? Just replace the head gaskets, got it all put back together and now it wont start. Fires up with starter fluid but dies when the fluid burns up.
Avatar Asked by Txgiant31
Answer
Replied on September 13, 2010
ignition timing is controlled by PCM. ensure timing marks on belt are aligned properly. The timing belt on the 3.2 SOHC does not get installed at tdc#1 the crank pulley has a half moon cut-out that positions at 3oclock and the slots on the cam pulleys point at raised dots on the rear cover
http://www.2carpros.com/forum/automotive_pictures/261618_Graphic_687.jpg
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
Which way do I turn the pulley? The info was very helpful! Thank u!
Tiny Response from Txgiant31
2 questions asked
the timing belt should have arrows of the correct direction , crank turns clockwise
Replied on September 14, 2010
Thanks! U have been a big help!!!
2 questions asked
