DRIVE BELT CHANGE - Serpentine belt
MIKE2005
  • 2000 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 98,000 MILES
I was driving my 2000 Isuzu Rodeo when my drive belt broke and found that the bearings in a pulley were totally destroyed so I replaced the pulley and drive belt but know my SUV is running poorly. Once I replaced the pulley and drive belt my SUV would not go over 40 miles hour and is idling poorly?
Sunday, January 18th, 2009 AT 12:45 PM
RACEFAN966
  • 5,029 POSTS
So what it the serpentine belt that you replaced or the timing belt? Did the car overheat when the belt broke? How hot did it get?
This guide will help you replace the belt
https://www.2carpros.com/diagrams/isuzu/rodeo/2000
Monday, April 8th, 2019 AT 6:26 PM
MIKE2005
It was the serpintine belt and no the vehicle did not overheat but it did reach normal temperature faster being it was -2 deg.
RACEFAN966
  • 5,029 POSTS
So when the belt broke did you check the antifreeze level and how low was it? If it was low it may have gotten hotter then the guage picked up. So you have it cold too in december we where -15 and better for a week here in North Idaho. We are much warmer no with 15 above taking the windchill in factor. I also must ask is it blowing any smoke out the tailpipe like black or blue or any other color? Also how much exhaust it coming out the tail pipe is it good and steady and increase when you have someone throttle it or does it seem to be the same all the time? Get back to me and we go from there.
MIKE2005
No black or blue just blowing white smoke do to the cold weather and the antifreeze level is fine. Could there be a timing/belt issue do to the serpintine belt breaking?
RACEFAN966
  • 5,029 POSTS
Ok do you have a check engine light on or does it come on? If it does then call around and see if any of your local parts stores will do a free scan and get the codes and then clear them and give me the codes.
Now when was the last time that the timing belt was replaced?
When the belt broke it didn't hit anything and maybe diconnect the mass air flow meter or break any wires to it or anything like that did it? Let me know what you find and we will see where we go from here.
ROTTDAWG00
  • 1999 ISUZU RODEO
Six cylinder all wheel drive automatic 102,000 miles.
I am in need of a diagram showing the routing of the serpentine belt. Cannot figure it out. Help!
Friday, June 19th, 2020 AT 12:53 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_izu_1.jpg
:D
NATESTRADAMUS
  • 1998 ISUZU RODEO
  • 3.2L
  • 6 CYL
  • 4WD
  • 238,000 MILES
Belt keeps bumping off. I have changed out both pulley and an alternator. What else could be causing this?
Friday, June 19th, 2020 AT 12:56 PM (Merged)
CARADIODOC
  • 33,752 POSTS
The power steering pump and generator are rarely the cause of a serpentine belt jumping off the pulleys. Look for a pulley that is turned or tipped in relation to the belt and other pulleys. The most common offender is the spring-loaded tensioner pulley. Next would be one of the idler pulleys. One way to find a turned or tipped pulley is to sight down along various pulleys to see if the side of the belt is peeking out. It should be perfectly inline regardless of where you look. If the belt is off-center by as little as 1/16", it will set up a squeal as it walks across the pulley as it goes around it.
When there's no belt squeal and it's tracking properly over every pulley, that's the time to consider something locking up intermittently which presents a sudden tug on the belt. That will cause the tensioner pulley to bounce and momentarily release tension on the belt. On GM products the generator often does that. On other brands, probably the air conditioning compressor would be the most likely suspect.
BORICUA428
  • 1996 ISUZU RODEO
  • 6 CYL
  • 150,000 MILES
I got the car with a bad water pump and broke time belt
i replace the pump at belt, the car will start and run with out any misfire. I see water coming out of the muffler. No smoke on idle only water with some dark particles
dont show milky oil or water at the oil sump or dipstik
will run for 45 min with temp gage show normal temp. After 45 to 50 minute will stop and wont. Start after 20 min will start and run for 30 min an stop. It will not misfire will runing.
Is there any good headgasket repaire that I can tried with out replacing the gaskets or what can I do to fix
or find the problem thx you
  • 31,938 POSTS
Hi there,
if this is diagnosed as a head problem, there is only one thing to do. And that is fix it properly, if you relay on cans of stop leak, you will only delay the inevitable and very possibly do more damage as well.
Mark (mhpautos)
DEBRAC17
  • 1994 ISUZU RODEO
  • 3.2L
  • V6
  • 4WD
  • 134 MILES
Need to find out how to connect fan since there is more than three holes to choose from. Need exact diagram of the three belts and sizes, etc. My vehicle is four wheel drive.
HMAC300
  • 48,601 POSTS
We do not have a picture of that. Just fit pulley and fan into which holes will line up with fan. See picture for belt diagram.
SHORTYLUVSU2808
  • 1994 ISUZU RODEO
  • 6 CYL
  • 130,000 MILES
I have a 1994 Isuzu Rodeo that makes a loud squeeking sound when I start it. I just had the engine rebuilt and the mechanic told me that it needed a new fan belt bracket. I checked with the local junkyards and they didnt exactly know what I was talking about. Is fan belt bracket the correct term? And also if I need a new bracket would I also need a new pulley?
  • 31,938 POSTS
Hi there,
you best go back to the mechanic that did the original job and get him to point out exactly what is required. Pulleys normally don't give any problems.
Mark (mhpautos)
3HAWKS1
  • 1994 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 120,000 MILES
My alternator belt got thrown off. There are 3 belts and this just happens to be the very back one. How do I go about getting the 2 front ones off to get to where I can replace this one? What tools will I need? Is there a tensioner (I don't see one) or do I have to loosen the power steering pump, etc. To do this job?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
Hello, 3hawks1
You must first loosen the pivot the slider bolts of each accessory, here is a diagram I found for you.
https://www.2carpros.com/diagrams/isuzu/rodeo/1994
You can see each pivot and slider (below)
Please let us know happens so it will help others. If this is not right please down vote and enter in a comment of why it is wrong please.
Best, Ken
JARRED DINKEL
  • 1994 ISUZU RODEO
  • 3.2L
  • V6
  • 4WD
  • 211,000 MILES
Where are the bolts to release the power steering pump belt?
Friday, June 19th, 2020 AT 12:57 PM (Merged)
  • 108,269 POSTS
Welcome to 2CarPros.
Take a look at the attached picture. If that is the set up you have, there is a slide adjustment on the lower right of the pump that moves when removed. Also, there are two mounting bolts behind the pulley that may or may not have to be loosened for the pump to actually move.
Take a look at pic one to confirm I have the right routing diagram. There are a few for this vehicle. If it is correct, loosen the slide bolt and the two mounting bolts behind the pulley. I have attached a picture of the pump so you can see where the two mount bolts are located. In the picture you can see the threaded holes.
If you look through the following link, it shows the different designs. If you see the one that is like your vehicle, let me know and then I know what you are dealing with.
Let me know if you have questions or if this helps.
JARRED DINKEL
On my 1994 Isuzu Rodeo 3.2ltr v6 Power steering is on bottom, A/C is on top.
