2002 Infiniti I35 Repair Question
Asked on July 14, 2010
2002 Infiniti I35 Driver Seat back/front control not workin
Electrical problem
2002 Infiniti I35 6 cyl Two Wheel Drive Automatic
The lever that allow you move the seat forward or backwards is not working. The same lever move the seat up and down and the other lever tilts the seat back.
I was thing it to be a fuse, but I don't know were to look. It could be the motor, but why doesn't the seat position work?
Answer
Replied on July 15, 2010
Hi Donald Martineau,
Thank you for the donation.
There are 2 motors used, one for sliding and the other for the back rest. Both motors uses the same fuse therefore it is not a power supply fault. Most likely the sliding motor is stuck and if you can try to turn the motor slightly and retest, it might work as the motor seldom fails due to it being not used that often.
