1996 Infiniti I30 Repair Question
Asked on October 7, 2008
1996 Infiniti I30
Suspension problem
1996 Infiniti I30 6 cyl Automatic 185000 miles
Is is time to call it quits? Just took my car in: needs water pump, new timing belt, rear brakes and - the kicker - the crossmember is rusted thru - only bolts on top are supporting the engine from falling out - can a support be replaced if the point it is attached is rusted thru?
