2003 Infiniti G35 Repair Question
Topics covered: Adapter, Gas, Oil cooler.
Asked on December 10, 2009
Oil leak
Engine Mechanical problem
2003 Infiniti G35 6 cyl Two Wheel Drive Manual 70000 miles
i have changed the gasket on the oil filter adapter twice and it is still leaking?
Answer
Replied on December 10, 2009
HI there, this adapter may be warped, ids this a paper gasket or a rubber "o" ring seal?
Mark (mhpautos)
Replied on February 19, 2010
Check oil cooler for cracks. Replace if found.
Make sure both mating surfaces are clean.
O-ring should aways be replaced after each disassembly. Never hurts to apply a little fresh oil to the new O-ring during assembly.
Align top cutout notch on oil cooler with protrusion on upper side of block. Tighten connector bolt to 36 ft-lb.
If still leaks, then I agree as mentioned adapter probably warped.
