Images (Click to enlarge)
Jan 11, 2013 at 2:54 PM
RIEBED
MEMBER
HI
Can you give me step by step instruction on how to change a cabin filter on a 2002 hyundai sonata? smells like spoiled meat with blower on-mechanic thinks a mouse got into the system-hopefully a cabin filter replacement will do the trick
Jan 15, 2019 at 5:03 PM
(Merged)
SATURNTECH9
CAR REPAIR CONTRIBUTOR
Why do think he died on the cabin air filter?Thats highly unlikely most of the ones i have seen were killed by the blower fan and thats were the mouse will most likely be on the blower fan wheel or close by it.
(Merged)
RIEBED
MEMBER
Thanks-I am going to drop the blower moter anyway-it looks real easy-and then I can just clean the cage well
(Merged)
SATURNTECH9
Alright let me know how it goes.Also i would get a ac duct cleaning kit the expanding foam kind.After you have found your animal.
(Merged)
RIEBED
MEMBER
sure enough ther was a dead mouse decomposing on the blower wheel-I removed it cleaned out the blower well as good as I could-some residual mild oder, but I hope it will graually go away as time goes on-or I will get the AC duct cleaning kit-but thanks again for your help
(Merged)
SATURNTECH9
Your welcomes thats what were here for.Thats what i thought with my rodent expernice thats where they usually die when there in the ducts.I have been usuing the parts master ac duct duct cleaning kit it has the foam that goes in the ac drain and the spray that goes in the ac fresh air duct later
(Merged)
JOSEPHR
MEMBER
2004 Hyundai Sonata 4 cyl Front Wheel Drive Automatic
How do I replace the air cabin filter ? if there is one ?
I took the glovebox out but didnt find it . must be or maybe no filter on the 04 ?
(Merged)
BLUELIGHTNIN6
Hello and thanks for donating
(Merged)
WACKEY JACKIE
MEMBER
1 POST
can"t fine it
(Merged)
HMAC300
it depends on the build date what I am sending is prio rto 3/03 if it's after that then its' different. you have ot pull the glove box out to get to it. there are 6 screws and pic I took this from doesn't show all . there are 2 10mm bolts as well.
(Merged)
