2CarPros - Car Questions & Answers
2003 Hyundai Santa Fe Repair Question
Topics covered: Timing belt, Camshaft, Crankshaft.
Asked on July 9, 2009
Timing belt
Engine Mechanical problem
2003 Hyundai Santa Fe 4 cyl Four Wheel Drive Manual
dear 2carpros, my name is paul ,i live in maidstone kent UK. i wonder if you could send me some info on how to change the timing belt on a 2003 hyundai sante fe 2.4 petrol. I cannot access this info in the UK ,i tried to get the info from the US hyundai site but as i was not a US resident they declined the info. i would appreciate your help in this matter yours faithfully paul turner UK
http://www.2carpros.com/forum/automotive_pictures/379813_work_001_1.jpg
Avatar Asked by englishtallpaul
Answer
Replied on July 9, 2009
The manufacturer recommends the belt be replaced every 60,000 miles, except in California. In California, inspect timing belt at 60,000 miles, and replace as necessary.
REMOVAL & INSTALLATION
CAUTION: This application is an interference engine. Do not rotate camshaft or crankshaft when timing belt is removed, or engine damage may occur.
Removal
CAUTION:DO NOT rotate engine counterclockwise (as viewed from timing belt end of engine). If reusing timing belt, place reference mark on timing belt to indicate direction of rotation before removing.
Remove drive belts and drive pulleys from crankshaft and water pump.
Remove timing belt covers. To align timing marks, rotate engine clockwise so No. 1 cylinder is at TDC of compression stroke. Ensure camshaft sprocket timing marks align with upper surface of rocker cover. Dowel pin of camshaft sprocket should be pointing upward.
Remove timing belt auto tensioner.
If reusing timing belt, place mark on timing belt to indicate direction of belt rotation.
Remove timing belt.
Remove camshaft sprockets.
Remove plug at left side of block and insert a screwdriver to hold left counterbalance shaft in position. Screwdriver will have to be inserted at least 2.36" (60 mm). Remove oil pump sprocket nut and sprocket.
Loosen right counterbalance shaft sprocket mounting bolt. Remove tensioner "B" and timing belt "B". .
Inspection
Check belt teeth for cracks, damage and oil contamination.
Inspect sprockets for damage.
Check tensioner pulley and idler pulley for grease leakage and roughness in rotation.
Check sprockets and pulleys for wear, cracks or damage. Replace components if necessary.
Measure protrusion of auto tensioner rod.
From end of housing, auto tensioner rod should extend .55" (14 mm) on Sonata or .57" (15 mm) on Santa Fe. Replace auto tensioner rod, if not within specification. Place tensioner in a soft-jawed vise, and test resistance of rod. If rod can be easily pushed in with light vise pressure, replace auto tensioner.
Installation
Install crankshaft sprocket "B" onto crankshaft. Ensure flange is properly positioned. Lightly oil outer surface of spacer, and then install spacer onto right counterbalance shaft, with rounded edge of spacer inward.
Install counterbalance shaft sprocket. Tighten flange bolt tightly by hand. Align timing marks on each sprocket and on front case.
When installing timing belt "B", ensure there is no slack in tension side.
Install tensioner "B" in center of pulley of left side of mounting bolt, and in pulley flange toward front of engine.
Align timing mark of right counterbalance shaft sprocket with timing mark on front case.
To tighten timing belt "B", lift tensioner "B" so tension side is pulled tight. Tighten bolt to secure tensioner "B". DO NOT turn shaft, or belt will be over-tightened.
Ensure timing marks are aligned. Ensure center of span on tension side of timing belt "B" can be depressed by hand. Ensure belt deflection is .20-.28" (5-7 mm).
Install crankshaft sprocket flange and sprocket.
Ensure flange is mounted in proper direction, with chamfered side toward block.
Install special washer and sprocket bolt to crankshaft.
Tighten sprocket bolt to specification..
Insert long screwdriver through plug hole in left side of cylinder block to hold counterbalance shaft in position. Install oil pump sprocket, and tighten nut to specification
Install camshaft sprockets, and tighten bolts.
If auto tensioner rod is fully extended, place it in soft-jawed vise, and compress rod slowly until hole in rod lines up with hole in auto tensioner housing.
Insert stiff wire to hold rod in this position. Install auto tensioner, leaving wire in place.
CAUTION: If timing marks on camshaft sprockets do not line up properly, DO NOT rotate sprocket more than 2 teeth in either direction, or valve and piston will touch. If necessary to rotate camshaft sprocket more than 2 teeth, rotate crankshaft sprocket counterclockwise first based on the timing mark. After camshaft sprocket is properly timed, return crankshaft to TDC.
Install tensioner pulley onto tensioner arm (on 1999-01 models, pin holes should be in approximately 8 and 10 o'clock positions), and tighten bolt to specification.
timing marks of camshaft sprockets with notches on upper side of rocker cover and dowel pins straight up. Align crankshaft sprocket timing marks. Align oil pump sprocket timing marks.
On 1999-01 models, install timing belt around tensioner pulley and crankshaft sprocket. Secure belt onto tensioner pulley by hand. Pull other side of belt, and install it around oil pump sprocket. Install belt around idler pulley. Install belt around exhaust camshaft sprocket. Turn intake camshaft sprocket one tooth clockwise to align its timing mark with cylinder head top surface. Pull belt with both hands, and install around intake camshaft sprocket. Gently raise tensioner pulley so belt will not sag, and then temporarily tighten center bolt.
On 2002-05 models, align timing mark on each sprocket with the corresponding timing mark, and install the timing belt in the following order: crankshaft sprocket, oil pump sprocket, idler pulley, exhaust camshaft sprocket, intake camshaft sprocket, then tensioner pulley.
On all models, ensure timing mark of each sprocket is still aligned. When checking alignment of oil pump sprocket timing marks, remove plug from hole in left side of cylinder block and insert long screwdriver 2.36" (60 mm) or more to verify that counterbalance shaft is in position. After checking timing mark, reinstall plug using liquid gasket. Remove wire from auto tensioner.
Rotate crankshaft 2 complete turns clockwise. Leave in this position for about 15 minutes. Measure auto tensioner protrusion "A" (distance between tensioner arm and auto tensioner body). Ensure auto tensioner protrusion is .24-.31" (6-8 mm).
Install timing belt lower cover and upper cover. Note proper location of each bolt.
good luck
Need a tool or a tester CHECK IT @
http://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Need parts check it @
http://www.eautopartstore.com/
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_202.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_96.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic4_48.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic5_27.jpg
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic6_17.jpg
Tiny Answered by BMRFIXIT (expert)
19,733 answers provided
