My 2003 Hyundai Santa Fe intermittantly stalls while driving. It seems that the Crankshaft Position Sensor can create this type of proble. The "check engine" light does not stay on when restarted. Would the Cranshaft Sensor generate a code and would the check engine light be lit? Is it still posible that the Ccranshaft sensor still be suspect even though the "check engine" light is not on? Thank You
Apr 23, 2010 at 1:27 PM
