2002 Hyundai Santa Fe Repair Question
Topics covered: Brake pedal, Battery, Brake light switch.
Asked on May 21, 2010
2002 Hyundai Santa Fe brake lights stay on when car off and
Electrical problem
2002 Hyundai Santa Fe 6 cyl Front Wheel Drive Automatic 90,000 miles
My brake lights will not turn off when I remove the key (or any time for that matter). Drained my battery. Had to disconnect battery to get them to turn off.
What could be going on? How much is a reasonable "diagnostic test" cost for this? I'm getting all kinds of numbers and it sounds like they are hoping it is a more expensive electrical problem to fix.
Answer
Replied on May 21, 2010
most likely culprit is faulty brake light switch, located under driver dash above brake pedal arm. approx. 30 minutes to replace it..
Replied on July 22, 2010
Hopefully you have found your problem by now. I just ran into the same problem and the culprit was not the switch. On our 2001 Santa Fe there is a nylon pad on the brake pedal lever that pushes aginst the brake light switch to turn off the brake lights when the pedal is relesed and comes up. This pad disintegrated so the switch is no longer depressed when the brake pedal is released. I placed a small replacement pad for a cabinet door that had an adhesive back on the lever and it did the trick. At least until I can get the real part somewhere.
