Gear not changing
ANONYMOUS
  • 2007 HYUNDAI SANTA FE
  • 6 MILES
Gear not changing
Sunday, February 17th, 2013 AT 1:50 PM
  • 52,797 POSTS
Make sure the fluid level is good. Otherwise you will need a trans shop to further help you as the trans may have an internal failure.
Sunday, February 17th, 2013 AT 4:02 PM
THOMASDREEVES
  • 2002 HYUNDAI SANTA FE
  • 2.7L
  • 6 CYL
  • 4WD
  • 88,000 MILES
Car will not go in gear got engine diagnostic code called auto parts store code was bad shift solenoid d. Need to know location of solinoid
Monday, July 15th, 2019 AT 4:28 PM (Merged)
HMAC300
  • 48,601 POSTS
It's attached to valve body in transmission here is a diagrams and the solenoid wiring diagrams so you can see the wire color which tells you which one is which. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
JAMIEJONES
Thanks for this post I had to get a rebuilt valve body cost me $328.00 which comes with all new solenoids all fixed! I love this site.
JOHNARESCH
  • 2004 HYUNDAI SANTA FE
  • 6 CYL
  • AWD
  • 140,000 MILES
Transmission shifting not good. When I start it almost goes red line before it shifts from 1 to 2.
When I go to neutral then back to drive it shifts to next postions.
Can't up shift using the + option but can down shift using -. Shifting does not apearto be slipping rathet it does not shift as it should between gears in automatic.
MIKE.SHRUM
  • 43 POSTS
Is there anyway you could get codes checked to see if maybe there is some stored transmission codes. Autozone checks the check engine light but I cant recall if this will get the codes you want
JOHNARESCH
I have a code reader and will get info
No check engine light appears
daughter said car did this intermittently but ran fine
checked fluid and it is clear/clean
LLOFTUS
  • 2003 HYUNDAI SANTA FE
Transmission problem
2003 Hyundai Santa Fe 6 cyl All Wheel Drive Automatic
Just had flush because it was not shifting out of 1st. Dash indicator lights came on with "1" and "2" in yellow - now in green. Reving up to 3-5. Gear lights have never been lit. I have a feeling it is the transaxle control module in the console? Anyone know? It is sporatic - so leads me to believe transmission is not going on me.
Linda
KHLOW2008
  • 41,815 POSTS
Hi Linda,
Autozone provides free scanning services. Get the trouble codes retrieved and let me know the EXACT code so I can understand what is wong.
HEIRIO
  • 2001 HYUNDAI SANTA FE
  • 6 CYL
  • 4WD
  • 68,000 MILES
I have been having transmission problems for awhile now and no one can seem to figure out what the problem is. I was reading about the same issue that others seem to have.
For no real reason the computer will no shift and the truck will go into saftey mode I guess it is. When you can only go between 2nd and 3rd gear. I have had the battery changed and alternator changed bbecause mechanics have said it was a problem with the charging system. It still happens. It is like the truck does not always know when it should shift. I never had this problem until early last year and that was almost a year after I had the transmission looked at and the filter/fluid changed. I have nioticed that when slowing down to about 35 and even 30 the computer will not shift the transmission down to 3rd. It stays in 4th even though the RPMs are around 1200. It just seems like the shift computer is not working right. Would I be correct with my deduction?
2CARPRO JACK
  • 11,533 POSTS
Have you ever had the PCM scanned for trouble codes? If ht e PCM ses an issue, it will usually store a code that can helplead to the cure. Shifting issues can be relate dto vehicle speed sensors, or many other sensors or solenoids that can stick within the trans
BRAD386
  • 6 CYL
  • 208,000 MILES
Hi, I have a santa fe with a shifting problem this morning I pulled out of the drive way and put the car into drive and it said it was in drive aswell as tiptronic sport mode, and would not shift out of first gear, I thought it might be a code error but there is no check engine light checked the shifter to see if the tab might of been stuck on the tiptronic shift option, I figured out how to get it to shift up in gear by changing from drive to neutral and back to drive works fine that way but other then that nothing. Thanks, brad.
  • 108,192 POSTS
Brad, you need to have the linkage checked between the shifter and the transmission. Also, if it is electrical, a warning light should come on. At that point, the computer will need scanned to identify where the problem is coming from.
CORY GREEN
  • 2005 HYUNDAI SANTA FE
  • 1.4L
  • 130,000 MILES
My engine seems to not being shift gears like it should be. I noticed this morning my window was open and the whole area by the shifter was wet. So I started driving and my engine just keeps revving and not shifting gears. Also, when I put the car into Drive it has a two underneath it like its in sport mode. (Which I did use last night to get out of a ditch). I also noticed while driving it just go down to D 1 for no reason. Before today I have never noticed the 1 and 2 underneath the D and I am thinking it is stuck in sports mode somehow.
STEVE W.
  • 12,968 POSTS
Water has probably gotten into the switch. If it was just water, gentle use of a hair drier on the switch area may do the trick. But to get to it you will need to remove the cover.
