Alternator
GWHALPIN
  • 2004 HYUNDAI SANTA FE
  • 84,000 MILES
How do you remove the bottom alternator bolt for a 2004 Hyundai Santa Fe 2.7 liter engine? When I push the bolt towards the engine it hits the engine so I can't get the alternator off?
Saturday, November 5th, 2011 AT 4:54 PM
  • 108,164 POSTS
The bottom bolt is a long one so you may need to remove a bracket to get it out here sia guide to help walk you through the steps with diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Saturday, November 5th, 2011 AT 6:37 PM
LA MONA LISA
  • 2.7L
  • V6
  • AWD
  • 160,000 MILES
When on the road the car stop working, all power was of.
I all ready check the battery, it seems to be okay, I charge it but when I run the car the charge does not last for long.
I will appreciate your answer and experience.
Thank you
george
Tuesday, January 29th, 2019 AT 3:59 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Have the alternator tested for correct charging.
REALMADJACK
  • 2002 HYUNDAI SANTA FE
  • 6 CYL
  • FWD
  • 45,000 MILES
The alternator is located at the rear (close to firewall) and at the bottom of the engine. I allready have the sepentine belt removed. Should I access / remove the alternator through the wheel well?
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, it does look like the wheel well will be the best access point for your alternator..
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_204.jpg
JERRYB540
  • 5 POSTS
  • 6 CYL
  • AWD
  • 56,000 MILES
I had a diagnosis of a defective alternator, and I replaced it with a rebuilt in June. In September, the battery went dead again and Auto Zone said the alternator was bad. They gave me another one. When I put the second one in, I checked the voltage drop accross the battery cables and also their resistance. Both readings were well within specs. In December the alternator was bad again. Am I the unluckiest person in the world or could something else be damaging the alternator?
IMPALASS
  • 3,112 POSTS
Hello -
To better assist you is your vehicle just a GLS or LX. Also please tell me the engine size in liter and the 8th digit of the VIN.
I know you check the voltage across, but please go to Auto Zone (AZ) or and have them pull the codes to the car. Most important: Once they check your codes, if they find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. This is the main thing here, have them bring their tester out and check your battery and alternator with their tester.
JERRYB540
  • 5 POSTS
My 2002 Santa Fe is a LX. Engine is 2.7 litre V6. VIN is KM8SC73D42U173390.
IMPALASS
  • 3,112 POSTS
Hello -
Well, I wouldn't say you are the unluckiest person. . .. . ...at least they are free each time. . ..
Now, I do see a TSB that increased the V6 models from 95 amp to 110. . ...which one are you installing since AZ has both?
Charging System - Generator Update
Notes
Group
36 - ENGINE
ELECTRICAL
Number
02-36-021
Date
08-2002
Model
Santa Fe 2002
Subject
NEW 2002 SANTA FE 2.7L V6 GENERATOR
DESCRIPTION:
A new generator has been installed on 2002 Santa Fe 2.7L V6 engines beginning February 4, 2002. The differences between the generators are:
1. The generator current output capacity has been increased from 95A to 110A.
https://www.2carpros.com/forum/automotive_pictures/248015_1_130.jpg
The general appearance (see photos) and part numbers are different.
3. The new generator contains a tapped hole to allow for the mounting of an 02 sensor wiring clip.
VEHICLES AFFECTED: Model: 2002 SANTA FE with 2.7L V6 engine
Affected vehicle production date range: February 4, 2002
Affected VIN range: KM8SC13D42U238719
https://www.2carpros.com/forum/automotive_pictures/248015_2_83.jpg
JERRYB540
  • 5 POSTS
I do know this much so far: No error codes stored in computer. Alternator diode pattern is bad (same as on the last two) and battery check tests bad. I am installing a new battery and another rebuilt alternator. Same question: what is causing this?
IMPALASS
  • 3,112 POSTS
Hello -
My previous question to you was what amp alternator have you been installing?
CUSTOM123
  • 2003 HYUNDAI SANTA FE
Electrical problem
2003 Hyundai Santa Fe 6 cyl Automatic 237000 miles
I am having difficulty with the removal of the altanetor, the thru bolt, that attachs the alt. To the engine will not completely slide back. The head of the bolt hits the frame or housing of the fwd housing. The bolt needs about 1/4 to clear so the alt. Can be removed. I have been told to raise the engine of remove the entire r side of the front drive axle. Could you help me?
JERRYB540
  • 5 POSTS
It lools as though it was the 95 amp model, because that's what the original was. The model year is 02 but the vehicle was purchased in late 01.
DOCFIXIT
  • 18,828 POSTS
Hyundia does not provide instruction see diagram is that like your set up?
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_255.jpg
IMPALASS
  • 3,112 POSTS
Hello -
Thanks for the info.
Obviously I don't know for sure about why you keep burning them up... But...I am going with the TSB that the V6 models need the 110amp.
My thought...(See what you think)..... The 90amp is running all the time with no rest and burns out the diodes because it is too weak.........
At a certain point since it isn't putting out correctly it is going to affect the battery.........
JERRYB540
  • 5 POSTS
Have installed a new battery and a rebuilt 110 amp alternator. Will let you know if the problem happens again. Thanks
IMPALASS
  • 3,112 POSTS
Hello -
Thank you for the update............. Good luck
IMPALASS
  • 3,112 POSTS
Hello -
I was reviewing previous posts and wanted to provide you with this info. Looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
08-01-004
03/11/2008
Campaign 082 - Trailer Hitch Module/Wiring Replacement
08-01-003
03/03/2008
Campaign 081 - Hitch Mount Bike Rack Modification
03-01-012-1
01/01/2004
Campaign - PROM Update for O2 Sensor DTC's
03-60-004
10/01/2003
Campaign - Roof Rack Cross Rail Installation
03-01-001-01
03/01/2003
Campaign - Crankshaft Position Sensor, Replacement
03-01-013
12/01/2003
Recall - Tire Pressure Label Correction
NHTSA03V030000
01/01/2003
Recall 03V030000: Crankshaft Position Sensor Replacement
02-01-011
11/01/2002
Recall - A/T Cooler Tube Corrosion
JEDI33569
Electrical problem
2002 Hyundai Santa Fe 6 cyl Two Wheel Drive Automatic
Can some one tell me what components must be removed on the 2.7L GLS model to access the alternator for replacement?
BLUELIGHTNIN6
  • 16,542 POSTS
Remove or disconnect the following:
Negative battery cable
Drive belt
Alternator electrical connections
Alternator mounting bolts
Alternator
the lower alternator mounting bolt may have to be removed from the backside of alternator, this will require removing the right axle shaft.
