2001 Other Hyundai Models engines tries to turn but will not
2001 HYUNDAI
78,000 MILES • 6 CYL • FWD • AUTOMATIC
GMAHDI
car will not start. it sounds like it wants to it will crank but not turning on. I checked the fuses in the fuse box under the hood. the female 30 amp was blown. I replaced it with a 20 amp due to auto part did not have a 30 amp. When I installed the 20 amp car turned over and started, I can now see the digital mile reading. then it shut off after this I found a 30 amp at a different auto part but I can not duplicate it showing the digital readings of the miles. The radio comes on and the head lights are bright, power windows will not operate. I had some issues with the radio going in and out before this happened though.
the 30 amp fuse that was blown went to the ignition switch.
Jul 15, 2008 at 4:20 AM
