2001 Hyundai Accent
Engine Performance problem
2001 Hyundai Accent 4 cyl Front Wheel Drive Manual 74,000 miles
I was sitting at a stop light and the check engine light started to flash and the car started to run very rough. I took it to my local autozone and had them use their code reader, the reader showed a misfire on #4. I replaced the spark plugs with NGK's gapped at.044, that didnt fix the proplem but I turned over the engine with the plug out and did see a spark. I am going to replace the wires tomorrow and see if that helps. Any idea's? Could it be a coil pack or injector, if so how would I check those problems Thank you
April 3, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
