Mechanics
REAR WINDOWS DON'T WORK**
2003 Honda Odyssey
Electrical problem
2003 Honda Odyssey 6 cyl Front Wheel Drive Automatic 135000 miles
Hello there,
My two rear windows don't open. When I push the button I can hear the sound trying to open but they don't. I've tryed pulling/pushing but it don't seem to help. Can I resolve this or I need to take it to a electrical place?
thanks in advance!
RAFAELN
September 1, 2010.
Hi RAFAELN,
If you hear the motor running but the glass are notmoving up or down, the regulators are bad and you need to send it to a mechanic, not the electrician.
KHLow2008
Sep 1, 2010.
Thanks for the prompt reply, but it is not the glass going up or down, i'm having issues with the two back windows/flaps that open in and out.
Thank you!
RAFAELN
Sep 1, 2010.
Sorry for the mistake. Since motors are running, it could be a fault with the linkages and is not an electrical fault. To check the linkages, you would have to remove the trims.
KHLow2008
Sep 1, 2010.
No problem and excuse my ignorance, but after I remove the trims, what would be the next step, what will I need to inspect directly?
Thank you very much you guys are great!
Rafael.
AD
RAFAELN
Sep 2, 2010.
After removing the trims, operate the motor and see if anything is out of the ordinary.
Ensure the windows are not stuck due to inactivity for prolonged periods. While operating the window switch, get someone to manually push the glass to assist the motor to see if it works.
KHLow2008
Sep 2, 2010.
AD
