ok i have a 89 crx si 5speed and my engine wont start it was running fine for 2 weeks and then it started and stayed idled for no more then a few seconds then shout off and then when it did that i tryed taping the gas and it stay on untile i stoped tapping the gas and$ now it stoped doing that i have a 97 sohc vtec d16 engine swap from out of a del sol, obd0 to obd1 with the dizzy im not to shore of what the problem is i changed the spark plugs and spark plug wires and it still wont start all it does is rotate the engine im stuck on what the problem is and how to test it to see how to fix it ............... if u need pictures of the engine bay just let me know thanks for the help if you know the problem
Mar 4, 2010 at 1:54 PM
