1989 Honda CRX Car stalled now won't start
1989 HONDA CRX
206,000 MILES • 4 CYL • FWD • MANUAL
BARRETTRANNEY
This originaly started out a little over a month ago when it stalled out, it took nearly two weeks of attempting to start the car before it fired up, which invluded new plugs, a new main(fuel) relay, an oil change (figured couldn't hurt it) new thremostat as I thought it had over heated. Put the car on a charger for the next day as I didn't want to push start and it took nearly two days but it fired up and worked for only a few days here I am with it not firing up again. The ecu is giving me code 16 which is related to the fuel injectors which I had cleaned and tested in december when I bought a new throttle body, so I'm rather stumped, the local honda dealership and another shop both said the ignition coil would be the culprit, well I've read a lot of good things on this site for other things in the past so figured I'd check with you all first, think it's the ignition coil or something else?
Apr 11, 2008 at 5:59 PM
