how do i remove front CV axle
2002 HONDA CRV
74,000 MILES
TBLASENGAME17
I'm trying to remove the front passenger side axle for replacement can you help me please I love this site!
Sep 8, 2011 at 9:27 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Diagrams shows some of the things you need to remove. The lower ball joints would have to be removed. It is not necessary to remove the complete knuckle as you can flip the knuckle outwards to separate it from the axle shaft.
Sep 9, 2011 at 1:33 PM
  • 54,352 POSTS
This guide will show you how to get the job done.
https://www.2carpros.com/articles/replace-cv-axle
Here is a video of the job bring done
https://youtu.be/9OYxj9y3Zjc
Cheers, Ken
Nov 2, 2017 at 6:56 PM
CGTOUCH
Drive Train Axles Bearings problem
2002 Honda CRV 4 cyl Four Wheel Drive Automatic 147000 miles
I have an 2002 hHond CRV and would like to replace my CV joints on the front of my 2002 CRV EX. I would like a diagram or something to look at to do this if possible. I have ordered my CV joints
Nov 3, 2017 at 1:19 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi cgtouch, Hope the following is helpful.
https://images.2carpros.com/forum/automotive_pictures/192750_CVShaft02CRV_2.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_CVShaft02CRV01_2.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_CVShaft02CRV03_2.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_CVShaft02CRV04_2.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_CVShaft02CRV05_2.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_CVShaft02CRV06_2.jpg
HOMEMECH
Shakes or Wobbles problem
2004 Honda CRV 4 cyl All Wheel Drive Automatic 52,000 miles
I just replaced the cv axle on our 2004 Honda CRV. There was a clicking noise during right hand turns, so I replaced the right side CV axle. Now there is a modest vibration in the front end, but only at around twenty miles an hour. It goes away as speed increases. I noticed that the new axle came with a rubber disk in the middle of the shaft. Maybe this is for balancing, but could it also be throwing the axle out of balance? Is there an adjustment I can make, or a way I can tell if the new axle is bad? Any help would be greatly appreciated. Thank you.
F4I_GUY
  • 3,302 POSTS
Axles can cause vibrations. I would ensure everything is good and tight and in it's proper position. Check your balljoint, axle nut, etc.
If that is fine, the axle is most likely defective.
COVINAB
1999 Honda CRV 4 cyl Two Wheel Drive Automatic 130000 miles
The Firestone Auto Care suggested I replace the right front half shaft. My old Firestone Auto Care store had replaced my left front half shaft some years ago. I have driven this vehicle on a mail route for it's first 100000 miles. I don't trust this new Firestone store person and need your advice.
KHLOW2008
  • 41,814 POSTS
Hi covinab,
If during tight turns with slight acceleration youhear a crocking noise, it most probably is due to a bad CV joint.
Turn the wheel fully to right and visually inspect th CV joint rubber boot. If it is torn and the greas is spilled all over, the joint is bad.
