2CarPros - Car Questions & Answers
2003 Honda CRV Repair Question
Topics covered: Engine, Sensor, All wheel drive.
Asked on September 10, 2008
Codes p0134, p0300, p0301, p0304
Engine Performance problem
2003 Honda CRV 4 cyl All Wheel Drive Automatic 82000 miles
Any ideas on what's up with my engine? At first the only code was P0301. When the vehicle is on an incline,with the front higher than the rear, and the engine is cool, it will run kinda rough as if almost shutting off.
The code originally was a cylinder 1 misfire.
After two days the code went to cylinder 1 misfire, cylinder 4 misfire, random misfire, and O2( the chilton book says fuel/air ratio) sensor no activity.
My mechanic originally said the #1 coil pack was bad but now I don't know. Please help me!!!!
Avatar Asked by rayminater
Answer
Replied on September 10, 2008
Hi rayminater,
Thank you for the donation.
The misfirings are all related and I would suspect the cause to be the O2 sensor.
A diganostic test is recommended to check the O2 sensor readings when in operation.
Check for vacumn leakages first.
Tiny Answered by KHLow2008 (expert)
40,332 answers provided
