Mechanics
BATTERY LIGHT IS ON
1997 Honda CRV
Electrical problem
1997 Honda CRV 4 cyl All Wheel Drive Automatic 172000 miles
I have a battery light on in my CR V. I see one belt in the engine. It is to the right as you look under the hood. It is working fine. Is there another belt that may have broken and causing the battery not to charge? Or is this simply an matter of needing a new battery? I did find that the battery cells were in need of fluid.
Lawofficemouse
September 17, 2008.
Hi lawofficemouse,
The charging system is faulty and you need to check the alternator, its belt and fuses.
Battery condition is a different problem.
KHLow2008
Sep 26, 2008.
AD
