1999 Honda Civic
1999 HONDA CIVIC
BVALDEZ81
1999 Honda Civic 4 cyl
ok?? so how do i check engine compression? my post was very detailed; however the response I received from my ASE service tech that replied, was not..
My car is running on 3 cylinders only. I have done the spark plug test and located the bad cylinder. I have changed the waterpump, thermostat, timing belt, spark plugs, spark plug wires, a fan sensor. I want to know what could still be causing my problem? At first it would die after I would put it into drive and accelerate, now I having a hard time even getting it to start. What could be the issue? I have also used the Seafoam fuel treatment..Could it be the fuel filter?
Sep 5, 2010 at 3:20 PM
