When I brake pulls right
MARKSILVA88
  • 2008 HONDA CIVIC
  • 1.8L
  • 4 CYL
  • 300,000 MILES
Just replaced all brakes and brake calipers. Suspension and tires about two months old.
Wednesday, May 22nd, 2019 AT 4:48 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your vehicle's Vehicle Stability Control Unit (VSA). It control not only the brake system but the steering system as well. I have included an exploded diagram of the VSA system and a description of it's operation in the diagrams down below. Please go through the information and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Thursday, May 23rd, 2019 AT 10:59 PM
MARKSILVA88
Brakes are mushy when brake pedal is applied. Going to bleed brake system this weekend to see if that helps. Also noticed that with the car off the ground in jack stands I can fairly easy move my wheels left and right with the car turned off. How do I fix the issue I am having?
Sunday, May 26th, 2019 AT 12:40 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I have included the information that you required in the diagrams down below. It requires the use of a 40mm and 42mm lock nut wrench though. I have also included a Technical Service Bulletin (TSB) that may be of use to you. I'm not sure if your vehicle is included and the time has run out by a couple of months but if your vehicle is an affected one, you might be able to have the service manager repair it for you under customer loyalty so you wouldn't have to pay for it. A phone call can't hurt, all they can do is say no. Anyway get back to us with how things turn out.
Thanks,
Alex
2CarPros
Sunday, May 26th, 2019 AT 3:04 PM
FREEMBA
  • 1,152 POSTS
Try bleeding the brakes. It's likely that air got into the system when the brakes were done. If that's the case it seems that the right front caliper is applying but the left one is not (or at least not enough). This will cause a pull to the right when the brakes are applied.
** You must bleed all four brakes; even-though you only changed the front brakes because each piston in the master cylinder controls one front and one rear brake. The master cylinder has 2 pistons.
** Brake bleeding begins with the rear passenger side wheel, followed by the rear wheel on the driver's side. Then, the front passenger side wheel and lastly the drivers side wheel.
** You may need to repeat the process if it's not satisfactory at first.
One question: When you say that the steering wheel goes left (when you hit the brakes), do you mean that the steering wheel is turning clockwise or counter-clockwise?
Thursday, May 28th, 2020 AT 6:07 AM
MARKSILVA88
Was a loose bolt.
Thursday, May 28th, 2020 AT 7:03 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,304 POSTS
Nice work, we are here to help, please use 2CarPros anytime. Can we ask which bolt was loose?
Friday, May 29th, 2020 AT 11:12 AM
CARADIODOC
  • 33,760 POSTS
Tires can cause a pull but so can a misalignment problem. Caster is not adjustable on your car and changing it won't cause or correct a pull.
The first question is did this just start suddenly or has the pull been there for a while? The only way to know if the alignment is off is to have it checked. The mechanic is going to inspect the steering and suspension system components first. Worn struts and lower control arm bushings will cause a pull too due to changed alignment. He will also "read" the tire wear patterns for clues to the cause of a problem.
Friday, May 29th, 2020 AT 11:15 AM (Merged)
COOKY101
Thanks for the response.
I took the car to a specialist in alignment on the weekend.
He did adjust it - very accurately - but even he accepted that there was some bias to the right hand side. He checked the bushes and the suspension and the rack.
He noticed there is a little play in the rack, suggested that this could be the issue?
The main issue is the steering effort - it is biased to the right! Only slightly, but I can feel it all the time.
These things have EPS - could the torque sensor or rack ecu have any input in this? - I am stumped - so are all the mechanics I've tried :-(
CARADIODOC
  • 33,760 POSTS
One thing to try is to disconnect everything electronic associated with the steering. It doesn't matter which circuit or system it is, adding a computer to it greatly increases the cost, diagnostic time, unreliability, and frustration, but the engineers have somehow determined that's what we want. With the electronic portion disabled, treat the steering just like on any other car. It would be helpful if you would post the readings for "caster" and "camber" for both front wheels. Normally caster is not adjustable on front-wheel-drive cars because it has such little affect on pulling compared to on rear-wheel-drive cars, but still, as it increases, steering effort gets harder. That is what provides the road feel and stability too.
Unequal caster, which causes a pull on rear-wheel-drive cars, can be offset by a similar offset of camber. While the car will go straight on level roads, the two tires will be pulling equally in opposite directions to offset each other, but for different reasons. (Think of putting a ten-pound weight on your right shoe, and a ten-pound weight in your left hand. You'll be in balance as long as you're standing still with your hands to your side). Your steering will be in balance as long as you're on a level road with no bumps. No roads are level. Most slant down to the side you're driving on so rain will run off.
Since caster is non-adjustable on your car, if it is not equal on both sides, the mechanic may need to adjust in a little difference in camber to offset it. While that can make the car go straight most of the time, you'll still have a higher steering effort in one direction. (In this case, think of a 50-pound child at the end of a teeter totter, and a 100-pound person halfway out on the other side. That will also be in balance, but to move either one of them individually, it would take more effort to move the 100-pound person up and less effort to pull him down).
I'm not sure what you mean by "bias". If you're experiencing a difference in steering effort from one way to the other, observe how the steering wheel returns too. When caster is unequal, you will typically find, (for example), the steering wheel turns easier from centered to the right than from centered to the left, but you would also find it RETURNS from left to centered easier than from right to centered. If you find it turns harder from centered to the right AND from left to centered, that points to a problem in the rack and pinion assembly.
Other things to consider are a tight ball joint and binding upper strut mounts. Most of the time those just cause harder-than-normal steering at all times, but that can be aggravated by having more weight on one side of the car.
DANFOWLER
  • 2005 HONDA CIVIC
  • 6 CYL
  • FWD
  • MANUAL
  • 15,000 MILES
Hi there
I think the details on the car are reasonably correct - its my girlfriends car and she's pissed. It's a Honda Civic Sport 1.6.
The issue is it's pulling to the left. Its been in twice to solve the problem (wheel alignment), and the Honda dealers keep saying its fine, but you have to keep a firm hold on the wheel to keep it in a straight line.
What should I ask to be done to properly correct the problem so they can't just fob her off again.
Friday, May 29th, 2020 AT 11:16 AM (Merged)
BLACKOP555
  • 10,371 POSTS
First you should be checking the wheel bearings and make sure they are still good, also make sure the brakes are not dragging.
The steering linkage may have to be adjusted if those arnt the culprits.
DANFOWLER
Thanks for the reply mate, appreciate that
AUTOTECH81
  • 2002 HONDA CIVIC
  • 4 CYL
  • FWD
  • 123,000 MILES
I thought it was the alignment because the car pulls to the right, but I got that done plus new tires and the car still pulls to the right. Please Help! Don't know what else it could be. Thanks
KHLOW2008
  • 41,814 POSTS
Hi autotech81,
The term alignment is vastly misunderstood.
Wheel alignment consists of 3 sections
1. Sideslips = toe-in and toe-out
2. Castor
3. Camber.
Usually the sideslips is checked and alignment is deemed to be correct.
When vehicle pulls to one side, sideslips adjustment might not solve the problem and that is when you need to check the castor and camber.
Most cars nowadays are non adjustable for the above so when they go out of specs, it it telling us something is wrong with the arms, it bushes etc.
Check the arm bushes, steering linkages, tire pressure and wear.
GREENDEB99
  • 2001 HONDA CIVIC
Steering problem
2001 Honda Civic 83000 miles
I had a flat tire the other day and had to drive on it to get to a safe place to change it. Had to buy a new tire, which my local gas station provided-said they balanced it first. Now my car pulls slightly to the right. It has not done this before. Can you tell me what this might be due to?
F4I_GUY
  • 3,302 POSTS
Check to make sure the tire inflation is correct. If so, it may be because you now have two different tires on the front wheels.
If thats not the case, you need an alignment.
HEATHERANN
  • 2000 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 130,000 MILES
I just replaced the tires and had the car aligned, it is still pulling to the right and it is shaking at 70 rpms, got it aligned a 2nd time in a week to make sure it was properly done and it is still shaking and pulling to the right, it looks like the ball joints are good also. What else could it be.
F4I_GUY
  • 3,302 POSTS
Post up your numbers. Make sure to include SIA spec. Most alignment shops don't even check secondary alignment angles, so you may just need a good alignment tech.
MANDALOISANN
  • 2002 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 168,220 MILES
I went to a local car repair shop to have my front struts replaced on my 2002 Civic. They completed the strut replacement and did an alignment. When I drove off in my car, I immediatley noticed a rubber rubbing sound when I turned to either side. I also noticed a kind of popping sound and that the car pulled hard to the left. I turned right around and took it back to the shop. They test drove the car and told me that the rubbing and popping sounds were due to the new struts and that this should subside as the struts "seat" themselves. They re-checked the alignment and I was advised that the car pulling to the left was "radial pull". I drive on the highway daily and I am concerned about my safety. I am not sure if I should go back to the same shop and tell them to re-check the alignment for a third time, or if they could have messed something else up. I spent a lot of money to get this work done, and I want to make sure it's right!
Thanks
KHLOW2008
  • 41,814 POSTS
Hi mandaloisann,
If you are not satisfied with the results of the repairs, you ought to get back to them and insist that they get the problem resolved.
Get a second opinion if necessary.
Are you still getting the rubber rubbing noise? There should not be any such noises unless something is not installed correctly.
If the steering is due to radial pull, swapping the front tires should reverse the drirection of pull.
Get the lower ball joints checked.
