Speedometer does not work?
DBRAMBLETT
  • 1991 HONDA ACCORD
  • 4 CYL
  • FWD
  • 182,000 MILES
Accord Wagon speedometer and tac have stopped working.
Any suggestions about where to start troubleshooting?
Please advise where cable attaches to engine or transmission.
Monday, August 30th, 2010 AT 6:55 AM
KHLOW2008
  • 41,814 POSTS
Hi dbramblett,
Both meters are electrically operated.
Vehicle Speed Sensor is located on transaxle housing below the thermostat housing.
Tachometer receives its signal from the distributor and it could be a wiring, meter cluster or ignition coil fault.
Wednesday, September 1st, 2010 AT 1:30 PM
MERRYKATE
  • 1991 HONDA ACCORD
  • 122,000 MILES
I took the car to a mechanic because the transmission was leaking badly and the timing belt needed changing. He fixed the trans by tightening some bolts, and replaced timing belt, water pump, spark plugs and several tubes and belts related to the system. After that, the car will only run properly in 2nd. In D3, D4 and 1 it revs but never shifts out of first and there is no pickup. I can't get it above 25 mph - I guess, since the speedometer stopped working after his "repairs". He seems mystified, but he's willing to keep working on it. Do I take it back? If so, what is the likely cause of this problem?
Tuesday, July 14th, 2020 AT 12:57 PM (Merged)
RIVERMIKERAT
  • 6,110 POSTS
He may have left the speedometer gear out. If so, he probably torched the transmission. He may have also overtightened whatever bolts he tightened, causing a worse leak.
NICKL
  • 38 POSTS
  • 1990 HONDA ACCORD
  • 58,000 MILES
1990 accord with Auto 4sP trans, the S light blinks, and speedometer does not work. I replaced the VSS and problem still remains. I have a 17 code in the ECU and a 4 code in the TCM, I think they both point to the VSS, The Pin that protrudes into the VSS is turning when wheel is turning. Can someone point me to the wiring diagrams for the VSS? Unless you think I should try something else. Can Shifts and runs fine
PROMECHANIC
  • 536 POSTS
This is almost always caused by a bad TCM. I usually don't say this, but in this case I would probably just replace it. 90% of the time this will fix it.
It is possible that you are in the 10% that won't fix it, but not likely.
MOLSONCANADIAN
  • 81 POSTS
Promechanic is right, though you should give the VSS a try, as it might fix it and it not very costly.
NICKL
  • 38 POSTS
Figures, I'm in the 10%, replaced TCM and got same results, Can you recommend anything else or point me to wiring schematics? This problem started right after I replaced the coil in the distributor. Car was running terrible, after wires, plugs and cap did not solve the problem I replaced the coil, I noticed the cap seal must have been leaking and interior of cap seemed to have moisture. I replaced the coil anyway, but really think the problem was corroded contacts on the spade connectors. Probably just a coincidence, but within a day of getting it running again the trans problem started. Any suggestions would be appreciated.
NICKL
  • 38 POSTS
Does anyone know if the VSS is an input to the ECU and the ECU can be the problem, Since VSS and TCM did not fix the problem and wiring is a low probability, I think I am running out of probable causes. Anyone seen ECU cause this problem?
Tuesday, July 14th, 2020 AT 12:58 PM (Merged)
PANTERANEGRA
  • 12 POSTS
  • 1990 HONDA ACCORD
Engine Mechanical problem
1990 Honda Accord 4 cyl Front Wheel Drive 153000 miles
I just bought this car and the speedometer doesn't work
Will it be the VSS and if that may be the problem where is the VSS located.
I'm looking to buy a Service manual but in the mean time I need to fix this problem.
Thank you
10/28/08 UPDATE. I checked yesterday and found the VSS and it looks new so it has been replaced already. So there is something else to be checked out. Any help will be appreciated.
Thank you
KHLOW2008
  • 41,814 POSTS
Hi PANTERANEGRA,
If the Check Engine Lamp shows sometimes, then you need to check the VSS and its wiring connectors and circuit to ECM/PCM. You did not specify if it is an Auto Trans, which would have the S mode lamp blinking.
If there is no CEL or S mode blinking, then it should be the meter gauge assy that needs attention.
KEITHERTL
Had same issue, but has evolved into the s light doesn't come on at all now, and I have to use the key to unlock the transmission to put it into gear. I have to put in in low gear to start out as it is set to
PANTERANEGRA
  • 12 POSTS
Thank you for answering.
The car has automatic transmision. After I pulled the VSS sensor and looking at it of course it look new I put it back and now the speedometer is working? Not sure why. However the S light blinks intermittent and the transmision doesn't shift gears all the time it seems to be "stuck"on 2 you know the gears are 1/2/D3/D4 it doesn't change gears when I shift gears.
Thank you for your help.
NICKL
  • 38 POSTS
Problem ended up being bad VSS, I purchased a Dorman -Part No 911-750 sensor, I returned it for new under warranty and problem fixed. Thanks for your help guys.
KHLOW2008
  • 41,814 POSTS
Hi PANTERANEGRA,
The VSS wire connector could have been loose and when disconnecting and reconnecting has now been seated properly. You should check the socket for signs of contamination or oxidation.
As to the 'S' mode light blinking and trans not shifting correctly, you need to retrieve the Diagnostic Troube Code to enable rectification.
https://www.2carpros.com/forum/automotive_pictures/192750_SCS91Accord_2.jpg
Bridge the connector as shown by the jumper wire and turn ignition switch ON. Cout the number of flashes and come back with the result.
Prolonged flashes = 10
Short flashes = 1
Prolonged Pause = DTC separator
Shhort
PANTERANEGRA
  • 12 POSTS
Thank you for your replay KHLow2008
Sunday Nov. 2 I checked the vehicle again and found that both of the coolant temp. Sensor are defective I'll get new ones at the dealer tomorrow. Checked with autoparts and they don't have them///I saw that the previous owern of this vehicle had changed the radiator and fan but I figure he hadn't repalced tohse sensors because they look old. Also will check the codes tomorrow because I didn't know how to do it before your replay
you guys have been very helpfull than you so much.
PANTERANEGRA
  • 12 POSTS
KHLow2008 I had chack thermal sensor in the past and looks like thsese type of sensors are not all the same. The sensors are good(found out after spending big bucks on new ones).
Automatic Transmision
my problem is the transmison will not upshift these happened when the S switch was pressed or activated now is erratic even after I disconected the battery cable to erase the codes(I also disconected the S switch is that OK?)I try checking for a code but the S light blinks inttermitent or it goes off and the transmision works ok.
I really can do without the S switch function
I like to know what is causing that I have removed and checked the Speed Ctrl. Solenoids(applied 12V and sounds like they activate(clicking sound)
Another question is it common on Honda cars to have poor conection between points I've been reading on a manual and it talks a lot about poor conections between connector wires.
I have removed and cleaned the conectors for the ECM and A/T control unit it did not make a diference.
KHLOW2008
  • 41,814 POSTS
Hi PANTERANEGRA,
When the S light is blinking, an error has been detected by the Transmission Control Module and it might cause shifting problems. For this model, it is higly possible the TCM or shift solenoids are faulty with the symptoms you have described.
Disconnecting the S mode switch would not do anything to the blinking as it only disables the option of Sports Mode whose main job is to delay the shifting time which is controlled by the TCM.
The S light is also used as an diagnostic indicator and when it does not goe off after initial key on, than something is wrong with the TCM or its sensor circuits.
Did you bridge the wire connectors as advised? You need to do it to get the Diagnostic Trouble Code to find out what is causing the problem.
PANTERANEGRA
  • 12 POSTS
KHLow2008 I did bridge the connector on Sunday but there were no codes. The S light came on yesterday and of course the transmission got "stuck" on second gear then I stop to pick up something to eat turn off the car and when I got back to drive it the light was off and the transmission worked fine. When I got home tried to get the codes but there is no codes not sure what is happening.
The TCM where is that located and how expensive is that part. Is there much dificulty to replace it.
I did removed the shifting solenois and applied 12VDC and they sounded like they worked(clicking sound)not sure if that means they are ok.
Your been very helpfull
Thank you
KHLOW2008
  • 41,814 POSTS
Hi PANTERANEGRA,
If no codes are stored, then I would suggest bridging the terminals and test driving untill you see the S light flashing and at that time you can start counting the flashes of the S light.
The TCM is located next to the ECM as shown in the previous post and rmoval is not that difficult. I believe you can get it quite cheaply at any of the scrap yards. Of course a new unit would be quite costly.
PANTERANEGRA
  • 12 POSTS
Ok KHLow2008 I jumped the conector and the S light came on. It looks like code one(light would blink and stay on and then the same)
The S light comes on inttermitenly and at that moment the transmision goes into 2nd gear
any help would be appreciated
