Ignition timing is off?
1995 HONDA ACCORD
229,500 MILES • 2.2L • 4 CYL • 2WD • MANUAL
JUSTIN ALLEN SPAUR SR.
Okay, so I had oil in my spark plug cylinders. I had to change out the valve cover gasket kit. When I reinstalled the rocker arm assembly I think that I may have not checked to see if I moved the crank, but it doesn't run and also does not want to start at all. Any way I can fix the timing would be very appreciated. Thought about just getting a timing gun but I think the cam is just not at the right position. any help would really be a great Christmas present to me thanks. Okay, so I just stripped everything back down so rocker arm assembly is off so cam shaft is showing. How do I know the crank and cam are at right position to reinstall everything and set timing from distributor?
Dec 24, 2018 at 4:18 AM
DANNY L
  • CAR REPAIR CONTRIBUTOR
  • 5,648 POSTS
Here is what I found for your Accord. With engine running the ignition timing should be 13-13 degrees before top dead center at 650-750 RPM's. If you were just changing the spark plug tube gaskets on the valve cover I'm just curious as to why you removed rocker arm? I've attached two pictures for a timing reference. Hope this helps and thanks for using 2CarPros.
Danny-
Dec 24, 2018 at 11:14 AM
JUSTNAKENNY
  • 6 POSTS
How do I check if the timing is right on my 1996 honda accord and how do I change it if it's wrong. Yes, I have a timing light and I cannot figure out how to adjust the distributor. All I can find on the distributor are 3 anchor bolts that connect it to the engine. Thank you
Jan 11, 2021 at 4:00 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Loosen the 3 anchor bolts and turning the distributor clockwise would retard the ignition timing. Turning it anticlockwise would advance the ignition timing.
Timing mark is located on crank pulley and the correct timing should be the center mark of the 3 lines ( would be marked Red if the paint is still there).
JUSTNAKENNY
  • 6 POSTS
I loosened the 3 bolts and the distributor would only move about a 1/16 of an inch, which equals about the rest of the opening for the bolt to go thru. When I looked at the marks on the crankshaft, there are 3 of them. The firstone being TDC [ I Think ' and then one to left of the about 1/2 inch away and then the third one being to the left of that about another 1/2 inch. the one that is all the way left has the red paint on it and that one is roughly and I have to say roughly because I can't see it, almost right under the needle. I had to disconnect the wiring that went to the distributor inorder to get to the third bolt and now I have a { Check Engine Light }. Do you know how I can get rid of it?
Also, when I slowly ease the engine rpm's up to 1500-2200 I hear what I would call larger bearings knocking or floating or rattling, until the rpm's get to 2300. I can almost ALWAYS hear what sounds like valve chatter to me, which is what made me want to look at the timing in the first place. HELP. Thank you.
KHLOW2008
  • 41,814 POSTS
You need to retrieve the trouble code and find out what is causing the CEL to come on. Get a free scan done at Autozone and let me known the exact code.
Have you checked the valve clearanes?
JUSTNAKENNY
  • 6 POSTS
Hello, I'm sorry that it took so long for me to get back to you.
Autozone doesn't do the engine check light test here anymore, so, I went ahead and bought the little scanner. It's a cheap one, but it did tell me that it was a P0118 trouble and it allowed me to clear it.
I also look at a friends 1991 Honda today and his distributor had holes that were oval, which allows him to adjust the timing, where as mine has holes that are just slightly larger than the bolt that goes thru them. Meaning that there is no way for me to adjust it back and forth.
I was told that I can't adjust the valves, so no I haven't pulled the valve cover off to check them. During idle it sounds fine, it's not until I raise the rpm's up that I can hear them and I do mean hear them, until I get up to about 55 or 60 mph. In other words I hear them ALL of the time, when I'm in town and driving around. It sounds like they're not getting enough oil to me.
KHLOW2008
  • 41,814 POSTS
What engine do you have in your vehicle?
For 1996 models, valve clearances and ignition timing are adjustable. The description of the distributor indicates it is from a later model.
JUSTNAKENNY
  • 6 POSTS
Now I really feel stupid, because the only thing I can find about what kind of an engine it has in it, is under the hood where it says that it's in the THN2 family. And another place on the door that says that it was made 1/96. It does tell me that the valve lash is .026 on the intake and .030 on the ehaust on the first sticker. And that's all I can find. It also says that it's a VTEC on the valve cover.
KHLOW2008
  • 41,814 POSTS
At front of on engine block, just under the top radiator hose there is a flat surface with some alphabets and numbers. On it is the engine code and serial. Let me know what it says.
JUSTNAKENNY
  • 6 POSTS
F22B1
3454290
KHLOW2008
  • 41,814 POSTS
For your model, the ignition timing is controlled by the PCM so adjustment is not possible.
If the igntiion timing is incorrect, it could mean the timing belt had not benn installed correctly.
Valve lash is adjustable. I would recommend removing the valve cover to check the condition. If the lifters are not getting sufficient lubrication, it could mean the oil passages could be partially clogged resulting in abnormal wear. Removing the valve cover would allow you to have a visual inspection of the condition of components.
JUSTNAKENNY
  • 6 POSTS
Thank you very much for helping me and being so patient with me. I had a friend look at it and now it sounds a lot quieter.
Take care and God Bless.
KHLOW2008
  • 41,814 POSTS
You're welcome.
Glad to know you have positive news.
Have a nie day.
WAZOOAVENUE
Car failed emissions test and timing is set at 29 btdc
Jan 11, 2021 at 4:01 PM (Merged)
HMAC300
  • 48,601 POSTS
timing for 2.2L is 13-17 btdc but yo need a jumper to do this. Same thing for a 2.7L i'm including pic ofr jumper.Best thing to do with this is to change oil and filter, drive for about 15 miles on eway then get it tested, it should pass then.
VSASSER
  • 9 POSTS
ever since i had the water pump and timing belt changed on my 93 accord i have ALOT of trouble getting it started was told its prolly my timing....if the timing is off culd it cause the car not to satrt??? and where are the timing marks located
Jan 11, 2021 at 4:02 PM (Merged)
CUP1981
  • 133 POSTS
It could be the timing. Question is, has it been like this since the second you had the work done, or did it happen later. If it happened later, chances are that it jumped time. You can attempt to adjust the timing first, following the below procedure. If that doesn't work, you will have to remove and reset or replace the belt. Some techs do not correctly tighten the timing belt tensioner, so you may want to look into that, if you are able to get it back into time. I also attached some images for aid.
1. Remove the rubber cap from the inspection window of the cylinder block.
2. Start the engine and allow it to warm up (cooling fan comes on).
3. Connect the ORN/RED and GRN/WHT terminals of the service connector (BLU) with a jumper wire.
4. Connect a timing light to the No. 1 ignition wire; while the engine idles, point the light toward the pointer on the flywheel (for M/T), or on the drive plate (for A/T).
5. Adjust ignition timing to: 15~ +/- 2~ BTDC @ 700 +/- 50 RPM
6. Adjust as necessary by loosening the distributor adjusting bolts, and turn the distributor housing counterclockwise to advance the timing or clockwise to retard timing.
7. Tighten the adjusting bolts and recheck the timing.
8. Remove the jumper from the service connector and replace the rubber cap to the inspection window.
BRANDONTRUENO86
  • 35 POSTS
I know that you have to disconnect the vacuum hose to the distributor because it's the fuel injected model,but which timing mark do i place the distributor at? There are three marks and then 1 mark above those. The 3 look like a T.
Jan 11, 2021 at 4:04 PM (Merged)
Good morning,
I attached the picture of the timing marks for you to view. You will need to use a timing light that can read advance or adjust to show how much advance. Parts stores have them for rent or purchase.
You hook up the light to the battery and number 1 spark plug. Remove the hoses from the vacuum advance and aim the light at the pointer. Adjust the timing light to the solid mark as that is 0. Then read the scale on the light for the timing. Adjust to the specs below.
Fuel-Injected engine:
ALL MODELS: 13-17° BTDC (Red mark), (at 700-800 rpm in neutral).
TRAMOS2626
I have a 89 accord with 2.0L and Auto trans. 170K miles. I just bought it. Gross poluter has carb problems but when I was having it checked out the shop could not adj timing below 24 degrees. Specs show 13-17 degrees btdc in drive. Could the timing belt have slipped enough to cause this problem without damaging the valves or could it be that someone put the belt on incorrectly. Unknown if anyone previously tried the repair. It runs ok and I don't hear anything that seems like it is hitting inside the engine. I am in the middle of taking off the timing belt covers and pulleys in the way and wonder if there is a good way to hold the crank pulley to remove the crank bolt. I tried a 1/2" impact gun and it won't budge. Also I can't find any timing pointer, any ideas where I shoul be looking? Thanks for any help, Ted
2CARPRO JACK
  • 11,533 POSTS
Some timing marks are on the flywheel, look for a rubber plug on the bellhousing. Try heating the crank bolt up a little, that usually frees them up. Sounds like the cam is advanced 1 tooth. Most likely done at last timing belt replacement.Hondas are non-interference engines, I wouldnt worry about valve damage
