where is the cabin air filter located?
2011 HONDA ACCORD
30,000 MILES
DART
where is the cabin air filter located on a 2011 honda accord
Jun 10, 2012 at 6:48 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
The cabin air filter is behind the glove box here is a a guide and the diagrams below to show you how its done in your car.
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Jun 10, 2012 at 6:59 PM
TIM FUGATE
whats the location of the cabin air filter
Oct 27, 2018 at 4:09 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
cabin filter is located behind glove compartment. would you like replacement procedures?
TIM FUGATE
yes that would be great
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1113.jpg
JACHOUSE
Where is the filter located? How do I get to it?
BLUELIGHTNIN6
  • 16,542 POSTS
remove the glove box and glove box frame. the filter is located behind this , in the evaporater. remove the filter lid from the evaporator to replace the filters.
DAVE BRANTNER
Where is thwe cabin air filter located on the Accord?
You have to remove the glove box to get to it-see below: Dust and Pollen Filter Replacement The dust and pollen filter should be replace every 30,000 miles (48,000 km) or 24 months whichever comes first. Replace the filter more often if the airflow is less than usual. Remove the glove box.
https://images.2carpros.com/forum/automotive_pictures/12900_c1_53.jpg
Remove the bolt, the screws and the glove box frame.
https://images.2carpros.com/forum/automotive_pictures/12900_c2_45.jpg
Remove the filter lid (A) from the evaporator, then pull out the lower dust and pollen filter (B) and the upper dust and pollen filter (C) in that order.
https://images.2carpros.com/forum/automotive_pictures/12900_c3_19.jpg
Remove the filter (A) from the housing (B), and replace it. Install the filter in the reverse order of removal. Make sure that there is no air leaking out of the evaporator. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
JSTORIN754
Where would I find the location of the cabin air filter. I just had mine changed today and the part was 26.24 and the labor was 63.80. The next time it needs changing I'd like to sbe able to do it myself.
KHLOW2008
  • 41,814 POSTS
Hi jstorin754, Here are the procedures for replacing the cabin filter. CABIN AIR FILTER Removal & Installation 1. Open the glove box. Remove the damper from the glove box then let the glove box hang down.
https://images.2carpros.com/forum/automotive_pictures/192750_CabinFilter07AccordFig01_1.jpg
2. Remove the dust and pollen filter assembly from the evaporator case.
https://images.2carpros.com/forum/automotive_pictures/192750_CabinFilter07AccordFig02_1.jpg
3. Remove the filter from the housing and replace the filter.
https://images.2carpros.com/forum/automotive_pictures/192750_CabinFilter07AccordFig03_1.jpg
4. Install the filter in the reverse order of removal. Ensure arrow marks on edge of filter point in direction of air flow. Make sure that there is no air leaking out of the evaporator.
JERRYP
I am trying to locate the cabin air filter housing. Is it located in the inside of the interior or outside in the engine compartment?
KHLOW2008
  • 41,814 POSTS
Hi Jerry,
It is located inside vehicle behind the glove box.
